.NET
strange problem of double click event
15 REPLIES 15
Message 1 of 16
netcai
722 Views, 15 Replies
I use activex's double click event to define my own text editor function , but my code is work well only in no form state, once i use my own form , double click event will stop work.
the following is my code :
using System;
using System.Windows.Forms;
using System.Collections;
using System.IO;
using Autodesk.AutoCAD.DatabaseServices;
using Autodesk.AutoCAD.ApplicationServices;
using Autodesk.AutoCAD.Runtime;
using Autodesk.AutoCAD.Colors;
using Autodesk.AutoCAD.Geometry;
using Autodesk.AutoCAD.GraphicsInterface;
using Autodesk.AutoCAD.LayerManager;
using Autodesk.AutoCAD.PlottingServices;
using Autodesk.AutoCAD.Windows;
using Autodesk.AutoCAD.EditorInput;
using Autodesk.AutoCAD.Publishing;
using Autodesk.AutoCAD.Interop;
using Autodesk.AutoCAD.Interop.Common;
//using CaiSoft.Cad.AcadUtilities;
using AcadArxApp = Autodesk.AutoCAD.ApplicationServices.Application;
namespace CaiSoft.Cad.CaiCommands.General
public class DoubleClick
public static EventsWatcher ew;
[CommandMethod("Cai_StartDoubleClick", CommandFlags.Session)]
public static void StartDoubleClick()
if (ew == null)
ew = new EventsWatcher();
ew.StartEvent();
public static void DoubleClickEdit(Point3d pickPoint)
ObjectId id = GetEntityOnPickPoint(pickPoint);
AcadApplication app = (AcadApplication)AcadArxApp.AcadApplication;
bool loaded = false;
string dbclickArxName = "ACDBLCLKEDIT.ARX";
foreach (object obj in (string[])app.ListArx())
string name = (string)obj;
if (name.ToUpper() == dbclickArxName.ToUpper())
loaded = true;
break;
if (loaded)
app.UnloadArx(dbclickArxName);
if (id == ObjectId.Null)
AcadArxApp.DocumentManager.MdiActiveDocument.Editor.WriteMessage("\nPlease select a single entity!\n");
return;
else
AcadArxApp.DocumentManager.MdiActiveDocument.Editor.WriteMessage("\n" + id.ToString() + "\n");
Transaction trans = HostApplicationServices.WorkingDatabase.TransactionManager.StartTransaction();
try
Entity ent = trans.GetObject(id, OpenMode.ForWrite, false) as Entity;
if (ent is DBText)
//((DBText)ent).TextString += "test "; // this line works fine.
EditText(id, trans); // this line only works some time.
else if (ent is MText)
trans.Commit();
catch (System.Exception e)
MessageBox.Show(e.Message);
finally { trans.Dispose(); }
private static ObjectId GetEntityOnPickPoint(Point3d pickPoint)
ObjectId id = ObjectId.Null;
PromptSelectionResult res = AcadArxApp.DocumentManager.MdiActiveDocument.Editor.SelectImplied();
if (res.Status == PromptStatus.OK)
if (res.Value.Count == 1)
id = res.Value[0].ObjectId;
return id;
public static void EditText(ObjectId objId, Transaction trans)
//TextEditorForm is my text editor form
string text = "";
Entity ent = trans.GetObject(objId, OpenMode.ForWrite, false) as Entity;
TextEditorForm f = null;
if (ent is DBText)
text = ((DBText)ent).TextString;
f = new TextEditorForm(text, false);
text = ((MText)ent).Contents;
f = new TextEditorForm(text, true);
DialogResult dr = AcadArxApp.ShowModalDialog(f);
if (dr != DialogResult.OK)
return;
if (ent is DBText)
((DBText)ent).TextString = "";
string[] temps = f.Res.text.Split('\n');
for (int i = 0; i < temps.Length; i++)
((DBText)ent).TextString += temps;
((MText)ent).Contents = f.Res.text;
// Helper class to workaround a Hashtable issue:
// Can't change values in a foreach loop or enumerator
class CBoolClass
public CBoolClass(bool val) { this.val = val; }
public bool val;
public override string ToString() { return (val.ToString()); }
/// DocManForUI.
public class DocManEvents
public DocManEvents()
Do();
public void Do()
try
DocumentCollection m_docMan = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager;
// Used to plant and remove Doc or DB events if applicable.
m_docMan.DocumentCreated += new DocumentCollectionEventHandler(callback_DocumentCreated);
m_docMan.DocumentToBeDestroyed += new DocumentCollectionEventHandler(callback_DocumentToBeDestroyed);
catch (System.Exception ex)
Helper.ErrorMessage(ex);
public void Undo()
try
m_docMan.DocumentCreated -= new DocumentCollectionEventHandler(callback_DocumentCreated);
m_docMan.DocumentToBeDestroyed -= new DocumentCollectionEventHandler(callback_DocumentToBeDestroyed);
private void callback_DocumentCreated(Object sender, DocumentCollectionEventArgs e)
try
Document doc = e.Document;
EventsWatcher.documentCreated(ref doc);
private void callback_DocumentToBeDestroyed(Object sender, DocumentCollectionEventArgs e)
try
EventsWatcher.documentToBeDestroyed(ref doc);
} // end of class DocManForUI
/// DocumentEvents.
public class DocumentEvents
public DocumentEvents()
m_bDone = false;
m_docsTable = new Hashtable();
collectAllDocs();
Do();
public void collectAllDocs()
try
DocumentCollection m_docCol = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager;
IEnumerator docEnum = m_docCol.GetEnumerator();
while (docEnum.MoveNext())
Document doc = (Document)docEnum.Current;
addDoc(ref doc);
public void addDoc(ref Document doc)
if (!m_docsTable.ContainsKey(doc))
m_docsTable.Add(doc, new CBoolClass(false));
public void removeDoc(ref Document doc)
if (m_docsTable.ContainsKey(doc))
UndoADoc(ref doc);
m_docsTable.Remove(doc);
private Document m_doc; // Used as a temporary var only.
private Hashtable m_docsTable; // Document(key)/bool(value) pair
private bool m_bDone; // A flag to indicate if events have been planted.
// A counterpart flag to the On option in the UI.
public void Do()
if (m_bDone == false)
m_bDone = true;
else // Don't return because we may need to address some new docs.
try
foreach (DictionaryEntry entry in m_docsTable)
CBoolClass boolClassVar = (CBoolClass)entry.Value;
// Continue if events have alrealy planted for the specific doc
if (boolClassVar.ToString().ToLower() == "true")
continue;
m_doc = (Document)entry.Key;
AcadDocument acadDoc = (AcadDocument)m_doc.AcadDocument;
acadDoc.BeginDoubleClick += new _DAcadDocumentEvents_BeginDoubleClickEventHandler(doc_BeginDoubleClick);
boolClassVar.val = true;
//Helper.ErrorMessage(ex);
public void Undo()
return;
else
m_bDone = false;
try
IDictionaryEnumerator docsEnumerator = m_docsTable.GetEnumerator();
while (docsEnumerator.MoveNext())
DictionaryEntry entry = (DictionaryEntry)docsEnumerator.Current;
// Continue if events have alrealy been removed from the specific doc
if (boolClassVar.ToString().ToLower() == "false")
continue;
acadDoc.BeginDoubleClick -= new _DAcadDocumentEvents_BeginDoubleClickEventHandler(doc_BeginDoubleClick);
boolClassVar.val = false;
public void UndoADoc(ref Document doc)
try
if (!m_docsTable.Contains(doc))
return;
CBoolClass boolClassVar = (CBoolClass)m_docsTable[doc];
// Return if events have not been planted for it.
return;
m_doc = doc;
void doc_BeginDoubleClick(object PickPoint)
//Arx.Editor.WriteMessage("\ndouble click started!");
double[] pnt = (double[])PickPoint;
Point3d pickPoint = new Point3d(pnt[0], pnt[1], pnt[2]);
DocumentLock docLock = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument.LockDocument();
DoubleClick.DoubleClickEdit(pickPoint);
docLock.Dispose();
} // end of class DocumentEvents
/// EventsWatcher.
public class EventsWatcher
public EventsWatcher()
// Static global event watchers
public static DocumentEvents m_docWatcher;
public static DocManEvents m_docManWatcher;
// Helper functions
public static void documentCreated(ref Autodesk.AutoCAD.ApplicationServices.Document doc)
if (m_docWatcher != null)
m_docWatcher.addDoc(ref doc);
m_docWatcher.Do();
public static void documentToBeDestroyed(ref Autodesk.AutoCAD.ApplicationServices.Document doc)
m_docWatcher.removeDoc(ref doc);
public void StartEvent()
docManWatcherOnDuty();
docWatcherOnDuty();
private void docManWatcherOnDuty()
if (m_docManWatcher == null)
m_docManWatcher = new DocManEvents();
private void docWatcherOnDuty()
if (m_docWatcher == null)
m_docWatcher = new DocumentEvents();
/// Helper class including some static helper functions.
public class Helper
public static void StreamMessage(string str)
try
// Application.DocumentManager.Count should be used to check zero doc status
// MdiActiveDocument returns non null sometimes even if in zero doc status!
if ( AcadArxApp.DocumentManager.MdiActiveDocument != null
&& AcadArxApp.DocumentManager.Count != 0)
Helper.CmdLineMessage(str);
else
Helper.InfoMessageBox(str);
public static void ErrorMessage(System.Exception ex)
try
System.Windows.Forms.MessageBox.Show(
ex.ToString(),
"Error",
System.Windows.Forms.MessageBoxButtons.OK,
System.Windows.Forms.MessageBoxIcon.Error);
catch
public static void InfoMessageBox(string str)
try
str,
"Events Watcher",
System.Windows.Forms.MessageBoxIcon.Information);
// Please check the valibility of Editor object before calling this.
public static void CmdLineMessage(string str)
try
if (AcadArxApp.DocumentManager.MdiActiveDocument != null
&& AcadArxApp.DocumentManager.MdiActiveDocument.Editor != null)
AcadArxApp.DocumentManager.MdiActiveDocument.Editor.WriteMessage(str);
else
return;
15 REPLIES 15
Message 2 of 16
netcai
in reply to: netcai
no body help me?
Message 3 of 16
in reply to: netcai
This seems to work fine form me:
public class TestDoubleClick
Autodesk.AutoCAD.Interop.AcadDocument m_doc;
[CommandMethod("testdblclick")]
public void DoIt()
if (m_doc == null)
m_doc =
(Autodesk.AutoCAD.Interop.AcadDocument)AcadApp.DocumentManager.MdiActiveDocument.AcadDocument;
m_doc.BeginDoubleClick+=new
_DAcadDocumentEvents_BeginDoubleClickEventHandler(m_doc_BeginDoubleClick);
AcadApp.DocumentManager.MdiActiveDocument.Editor.WriteMessage("Double
click event is now hooked.");
else
m_doc.BeginDoubleClick-=new
m_doc = null;
click event is now unhooked.");
class MTextEditor : Form
TextBox m_textBox;
public MTextEditor()
m_textBox = new TextBox();
this.SuspendLayout();
m_textBox.Location = new System.Drawing.Point(0, 0);
m_textBox.Name = "textBox";
m_textBox.TabIndex = 0;
m_textBox.Multiline = true;
m_textBox.Dock = DockStyle.Fill;
ClientSize = new System.Drawing.Size(100, 100);
Controls.Add(this.m_textBox);
Name = "MTextEditor";
Text = "MText Editor";
this.ResumeLayout(false);
public string Contents
get {return m_textBox.Text;}
set {m_textBox.Text = value;}
private void m_doc_BeginDoubleClick(object PickPoint)
Document activeDoc = AcadApp.DocumentManager.MdiActiveDocument;
//get the object that the user has selected
PromptSelectionResult res = activeDoc.Editor.SelectImplied();
if (res.Status != PromptStatus.OK)
return;
if (res.Value.Count != 1)
return; //we don't handle multiple selected objects
ObjectId idSel = res.Value[0].ObjectId;
using (DocumentLock docLock = activeDoc.LockDocument())
using (Transaction trans =
activeDoc.TransactionManager.StartTransaction())
DBObject obj = trans.GetObject(idSel,OpenMode.ForWrite);
MText text = obj as MText;
if (text == null)
return; //not an mtext
using (MTextEditor form = new MTextEditor())
form.Contents = text.Contents;
AcadApp.ShowModalDialog(form);
text.Contents = form.Contents;
trans.Commit();
wrote in message news:4889347@discussion.autodesk.com...
no body help me?
Message 4 of 16
netcai
in reply to: netcai
Albert, thanks very much.
your code works well, but I don't understanding why my code doesn't work. Our code's difference is : I use a static method,you use a instance method.
Message 5 of 16
netcai
in reply to: netcai
one more question:
after I run my double click event, the dited object is highlighted, my question is how to make it unhighlighted,otherwise I must press twice esc key.
Message 6 of 16
netcai
in reply to: netcai
Albert, when I run your code, it works fine ,but when autocad exit, a error messagebox appeare, it shows "Unhandled Exception E0434F4D(e0434f4dh)" at address 7C81EB33h
Message 7 of 16
in reply to: netcai
Did you run unhooked the even before exiting (by running the command again)?
Albert
wrote in message news:4890685@discussion.autodesk.com...
address 7C81EB33h
Message 8 of 16
in reply to: netcai
Frankly, if you want to replace the mtext editor then I wouldn't approach
the problem this way: why don't you redefine the mtedit command like this?
[CommandMethod("mtedit")]
public void DoIt2()
AcadApp.DocumentManager.MdiActiveDocument.Editor.WriteMessage("My mtedit
command.");
It would be much simpler and more reliable.
Albert
wrote in message news:4890663@discussion.autodesk.com...
one more question:
key.
Message 9 of 16
netcai
in reply to: netcai
1. If I redefine mtedit command , I can't get the object on pickpoint use SelectImplied() method. and more I can't redefine ddedit command, my aids is to hanle all the objects double click event.
2. yes, I run the command again, but the error still exit.
Message 10 of 16
in reply to: netcai
1. You have to specify CommandFlags.UsePickSet like in:
[CommandFlags("mtedit", CommandFlags.Modal | CommandFlags.UsePickSet]
Why can't you redefine the ddedit command? You must undefine it first
because it is a built in command but you should be able to supply your own.
2. I can't reproduce this. I'm not sure what else you have going on in your
environment.
Albert
wrote in message news:4891655@discussion.autodesk.com...
Message 11 of 16
netcai
in reply to: netcai
Maybe I don't state clearly, I means I can't change autocad default double click command (ddedit,eattedit,refedit..) )with my command, because
1. autocad alway use .ddedit to response double click event, so my ddedit doesn't work.
2. I can redefine eattedit and refedit, I also use CommandFlags.UsePickSet flag as you say , but again SelectImplied() get nothing object.
Message 12 of 16
netcai
in reply to: netcai
I think the best way to realize custom double click command is to use double click event , but as I say befor, the problem is after finish my own command , the object edited is still highlighted and selected , and I must press "esc" key twice to continue my next work.
Message 13 of 16
in reply to: netcai
To use the current selection set in a command, you need
to include CommandFlags.UsePickSet in your command
handler's CommandMethod attribute:
[CommandMethod("YOURCOMMAND", CommandFlags.UsePickSet)]
http://www.caddzone.com
AcadXTabs: MDI Document Tabs for AutoCAD 2004/2005/2006
http://www.acadxtabs.com
Message 14 of 16
netcai
in reply to: netcai
tony , I can redefine eattedit and refedit, I also use CommandFlags.UsePickSet flag as you say , but SelectImplied() get nothing object.
Message 15 of 16
in reply to: netcai
I'm not sure what you are doing. This seems to work fine for me.
Albert
wrote in message news:4891851@discussion.autodesk.com...
object.
Message 16 of 16
netcai
in reply to: netcai
thanks, Albert. you are really a good man, with your help , I learn many useful things.
I have solved my problem of double click event. through calling a command(my own unhighlight method ) with SendStringToExecute method after my own double click event, I can unhighlight the object edited sucessfully.
but as you suggest , I can call my own double click command through redefine all commands related to double click , I trid ,but only mtext works, others command doesn't work.
when I undefine ddedit command in my lisp,autocad default ddedit command doesn't work in autocad if I directly run ddedit in command line, instead my own ddedit run , but when I double click a text, autocad will run its internal command .ddedit, not run ddedit,so my own ddedit command doesn't work in double click event through this method.
thanks again .
”Boost
