.NET
Strange closing forms
6 REPLIES 6
dmarcotte4
244 Views, 6 Replies
Maybe I am doing something wrong but when I call
this.Close();
on a form, If the command line is not docked and the dynamic input turned off, it does not release control correctly, the user must click on the drawing screen before entering a new command. Is this because I am using VS 2005 Beta 2?
Autocad 2006
VS 2005 Beta 2
Daniel
6 REPLIES 6
in reply to: dmarcotte4
Do you use
Autodesk.AutoCAD.ApplicationServices.Application.ShowModalDialog() to
display the dialog?
Albert
wrote in message news:4965259@discussion.autodesk.com...
this.Close();
2005 Beta 2?
Autocad 2006
VS 2005 Beta 2
Daniel
dmarcotte4
Hi Albert
That’s correct. I have a line
using AcadApp = Autodesk.AutoCAD.ApplicationServices.Application;
then I use
MyMainForm myForm = new MyMainForm();
AcadApp.ShowModalDialog(myForm);
I noticed the problem when my program didn’t perform the same at work where I have the command line and tool bars on a second monitor, where at home I have only one monitor and the command line docked. I guess I need to write code to ensure what gets focus after my form closes?
I"m not seeing this problem. Does the layer dialog have the same problem on
your machine (it is also .net form)?
Albert
wrote in message news:4966275@discussion.autodesk.com...
Hi Albert
That's correct. I have a line
then I use
I noticed the problem when my program didn't perform the same at work where
dmarcotte4
Yep, it happens with the layer dialog also. I have tested this on other work centers at my company but it’s not much of a test base since they are about identical machines. Weird
What is your form's FormBorderStyle set to?
http://www.caddzone.com
AcadXTabs: MDI Document Tabs for AutoCAD 2004/2005/2006
http://www.acadxtabs.com
wrote in message news:4967190@discussion.autodesk.com...
dmarcotte4
Hi Tony,
I have them using Fixed3D.
Daniel
”Boost
