.NET
Strange behaviour using GetBlockReferenceIds()
9 REPLIES 9
Message 1 of 10
jbooth
747 Views, 9 Replies
Good afternoon,
While testing our product on a target machine I noticed something a little strange: The GetBlockReferenceIds() function returned an empty list of ObjectIds even when references did exist in the drawing.
What's strange about this is that on my machine this does not happen, and that saving and reopening the document will cause GetBlockReferenceIds() to return the correct number of block reference IDs.
The only difference between the two machines (developer machine and test machine) is that the test machine has Service Pack 2 installed.
Both machines use Autocad 2007.
Has anyone else encountered this? Should I be worried that my users will need to close/open drawings constantly, or is there a workaround?
Thanks for any help you can give.
9 REPLIES 9
Message 2 of 10
jbooth
in reply to: jbooth
In case you wanted to see some sample code, here it is.
Message 3 of 10
in reply to: jbooth
What release of AutoCAD was the drawing that you
tried it on last saved in?
http://www.caddzone.com
AcadXTabs: MDI Document Tabs for AutoCAD 2008
Supporting AutoCAD 2000 through 2008
http://www.acadxtabs.com
wrote in message news:5583994@discussion.autodesk.com...
Good afternoon,
Message 4 of 10
in reply to: jbooth
Jason - Take a closer look at your posted code,
specifically this line:
If blockref.OwnerId = table(AcDb.BlockTableRecord.ModelSpace) Then
wrote in message news:5583997@discussion.autodesk.com...
Message 5 of 10
in reply to: jbooth
Another more general comment on your code, has to do
with Disposing of objects obtained through transactions.
I see quite a bit of that in code posted here and just
wanted to point out that doing it is pointless, and only
serves to needlessly complicate your code.
In general, any objects obtained through a transaction,
do not need to be explicitly Disposed.
That's because disposing the transaction you got the
objects from, has the same effect as disposing of the
individual objects themselves.
Message 6 of 10
jbooth
in reply to: jbooth
To answer your questions...
The template file I am using to create any new drawings was saved in R17 format, and the drawings are either saved by the user (using qsave) or are saved using:
ThisDrawing.Database.SaveAs(FileName, AcDb.DwgVersion.Current)
As for:
The intention was to limit objectId selection to modelspace. As far as I know, that part was working perfectly. The call to GetBlockReferenceIds() was where the code was failing.
Thanks for the heads up on the disposal of objects returned from a transaction.
Message 7 of 10
in reply to: jbooth
Your code uses = (assignment), but I think you
meant to use == (equality).
wrote in message news:5585039@discussion.autodesk.com...
As for:
Message 8 of 10
jbooth
in reply to: jbooth
in VB.NET, the = operator (when in an if statement) calls the Object.Equals() method. 🙂
I did change it to this though:
If blockref.OwnerId.Equals(table(AcDb.BlockTableRecord.ModelSpace)) Then
Message 9 of 10
in reply to: jbooth
Ok, sorry I must have thought I was looking at C# 🙂
wrote in message news:5585116@discussion.autodesk.com...
Message 10 of 10
jbooth
in reply to: jbooth
To follow up on this topic:
I changed my code to use COM interop (and selection set filters) and the problem went away. I've attached a sample (although it's pretty easy).
I'll modify this again once I finish looking up the DXF code for modelspace entities, as I know I'm doing a little extra work.
”Boost
