Hi all,
I defined a new PageSetup for a Layout:
- defined it with PlotSettings, PlotSettingValidator
- added it to the PlotSettingsDictionary
The PageSetup is created succesfully. When I manually set the PageSetup
current in a Layout, all works well.
But I have a some problems making this PageSetup current with code:
- I use oLayout.CopyFrom(oPlotSettings); with no errors.
- The appearance of the layout is not refreshed. When I start the Plot
dialog all settings show up correct (Plot area: "Layout", Scale: 1:1).
- When I do a Regen with the Layout active ("Regenerating Layout"), the
background becomes full white (no paper boundaries). When I start the Plot
dialog all settings still are correct.
- When I switch to Modelspace and back, suddenly the settings are changed!
: Plot area: "Extents", Scale: ScaleToFit. Other settings remain correct,
and the Paper boundaries are displayed now.
Does anyone know a solution for the changed settings problem, and the best
way to refresh the appearance of the layout?
Thnx,
Henk
