.NET
matus.brlit
Message 1 of 5 (226 Views)
Storing data in ResultBuffer
226 Views, 4 Replies
03-28-2013 12:35 AM
When storing data in ResultBuffer, I found, that there are DxfCodes, that seem to have the same meaning.
DxfCode.ExtendedDataAsciiString Vs. DxfCode.Text
DxfCode.ExtendedDataInteger16 Vs. DxfCode.Int16
Can anyone clarify if there is any difference between them?
matus.brlit wrote:
So in XData, I can use whichever I want, but elsewhere, I have to use DxfCode.Text and DxfCode.Int16 ? And where is that elsewhere? Because when storing data in XRecords, they are stored in the XRecortd's Data property, which is the same.
Maybe for communication with Lisp?
1. In XData you can not use DxfCode.Text and DxfCode.Int16 but can use DxfCode.ExtendedDataAsciiString and DxfCode.ExtendedDataInteger16
2. In XRecord you can use DxfCode.Text and DxfCode.Int16
Moderator
Alexander.Rivilis
Message 2 of 5 (208 Views)
Re: Storing data in ResultBuffer
03-28-2013 02:27 AM in reply to: matus.brlit
DxfCode.ExtendedDataXXXX can be used only as a part of extended data (http://through-the-interface.typepad.com/through_the_interface/2007/04/adding_xdata_to.html)
Пожалуйста не забывайте про Утвердить в качестве решения! Утвердить в качестве решения и Give Kudos!Баллы
Please remember to Accept Solution! Accept as Solution and Give Kudos!Kudos
matus.brlit
Message 3 of 5 (204 Views)
03-28-2013 02:45 AM in reply to: Alexander.Rivilis
Moderator
Alexander.Rivilis
Message 4 of 5 (191 Views)
03-28-2013 03:40 AM in reply to: matus.brlit
matus.brlit
Message 5 of 5 (183 Views)
03-28-2013 03:48 AM in reply to: Alexander.Rivilis
Thanks for clarification.
