Hi All,
I have 1 problem, hope everybody can help me. This is, How can i save polyline of 1 curve to access database. I have tried but fail. Because i recieve error:
"Multiple-step OLE DB operaation generated errors. Check each OLE DB status value, if available. No work was done". I don't know what does it mean. Thanks everybody.
It looks like a database access code issue, rather than anything to do with AutoCAD.
How do you "save" polyline in the said database? Do you say the vertex points? Do you use DAO or ADO or ADO.NET? Can you show the code that does the saving?
That error usually indicates some parameters passed into database access command have invalid values. In your case, without seeing the code, it is not possible to suggest anything more helpful.
Norman Yuan
