.NET
StartUserInteraction for AutoCAD 2013
5 REPLIES 5
1543 Views, 5 Replies
I'm trying to update some VB.Net code for AutoCAD 2013, and am slowly slogging my way through the API changes. Here's one I haven't been able to figure out yet:
The following line worked in pre-2013, but not anymore...
Dim eui AsEditorUserInteraction = Application.DocumentManager.MdiActiveDocument.Editor.StartUserInteraction(Me)
I get this error in the editor...
Error 12 Value of type 'IECAD.fSymbols' cannot be converted to 'System.IntPtr'.
IECAD.fSymbols is a form in my application, and the error references the Me in my statement. What is the current correct way to activate a form while allowing for user interaction (like picking a point)?
Thanks.
5 REPLIES 5
Never mind... I figured it out. Changing Me to Me.Handle did the trick.
Hope this helps someone else!
andrewpuller3811
Thanks for posting your solution.
If a post provides a fix for your issue, click on "Accept as Solution" to help other users find solutions to problems they might have that are similar to yours.
Andrew Puller
Maitland, NSW, Australia
Windows 10 Enterprise 64bit
Intel core i7 11800 @ 2.30 GHz with 32GB Ram
Civil 3d 2021
cfiene
Thanks for the solution! It was driving me caazy!!!
in reply to: cfiene
Glad to help!
mjsmith
Excellent post!!!! Thanks a bunch.
”Boost
