You can specify a script to run when AutoCAD starts.
See the command line switches for acad.exe in the help.
http://www.caddzone.com
AcadXTabs: MDI Document Tabs for AutoCAD
Supporting AutoCAD 2000 through 2010
http://www.acadxtabs.com
Email: string.Format("{0}@{1}.com", "tonyt", "caddzone");
wrote in message news:6327872@discussion.autodesk.com...
I want to start AutoCAD from an external application that does not have
references to AutoCAD api dlls but tell AutoCAD that he needs to run a certain
command. Can this be done using only ProcessStartInfo? Also the command that I
want to run is defined by an AutoCAD add-in. I was thinking about a Process
start with arguments.
