.NET
Distinguished Contributor
wesbird
Message 1 of 3 (110 Views)
SQL Server Express or higher?
110 Views, 2 Replies
02-14-2014 12:32 PM
  I'm evaluation Vault 2014 now, how do I dertermine which versin of SQL Server I should use, Express, Standard, or higher? where is the best practise? in the number of document, like 10,000 files? or size of documents, 10 Tb files?
Thank you so much
Wes
Hallex
Message 2 of 3 (104 Views)
Re: SQL Server Express or higher?
02-14-2014 12:42 PM in reply to: wesbird
I use succesfully SQl Server 2008R2 with A2014
without problem (either with C# and lisp)
dgorsman
Message 3 of 3 (87 Views)
02-14-2014 02:49 PM in reply to: wesbird
Is this a programming issue, or should it go under the dedicated Vault board?
Adopt. Adapt. Overcome. Or be overcome.
A good question will be halfway to a good answer.
