.NET
Active Contributor
cadmaxza
Message 1 of 7 (141 Views)
SQL Connection problem
141 Views, 6 Replies
01-10-2006 11:24 PM
I have compiled a stand alone application that connects to our sql server and reads data from the tables, providing searches. I have also compiled the same code as a dll to be used as a command in AutoCAD. But the dll exits at the sql connection string.
The error message is:
Request for permission of type 'System.Data.SqlClient.SqlClientPermission, System.Data, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089' failed.
The connection string includes the following info:
Initial Catalog
Data Source
Packet Size
User Id
Password
Any ideas? Have I missed something? Why doesnt the dll connect but the exe does?
Kevin.
Distinguished Contributor
ChrisArps
Message 2 of 7 (141 Views)
Re: SQL Connection problem
01-17-2006 04:49 AM in reply to: cadmaxza
This has got to be a sql server security issue, I use jet 4.0 mdb files from dot net and use the same dll from an external exe and inside of ADT/Autocad as well with no problems.
My guess is that the exe correctly builds the proper client info to use sql server and the dll does not.
Chris Arps
Mikko
Message 3 of 7 (141 Views)
01-17-2006 05:27 AM in reply to: cadmaxza
Just tried this with no problems.
Imports Autodesk.AutoCAD.Runtime
Public Class Class1
_
Public Sub AllUsers()
MsgBox(GetUsers().Tables(0).Rows(1).Item(0).ToString)
End Sub
Public Function GetUsers() As DataSet
Dim MyConnection As System.Data.SqlClient.SqlConnection = New System.Data.SqlClient.SqlConnection("server=sql-data;uid=YOUR_NAME;pwd=YOUR_PASSWORD;Trusted_Connection=false;database=WorkWithIt")
Dim MyCommand As System.Data.SqlClient.SqlDataAdapter = New System.Data.SqlClient.SqlDataAdapter("SELECT Email FROM Users", MyConnection)
Dim DS As DataSet = New DataSet
MyCommand.Fill(DS, "Users")
MyConnection.Close()
Return DS
End Function
End Class
Active Contributor
cadmaxza
Message 4 of 7 (141 Views)
02-01-2006 04:51 AM in reply to: cadmaxza
Aha!! It is a security issue (still not solved though). I have just written my first VB.Net code to make a text file and I have encountered a similar error message ... System.Security.Permissions.FileIOPermission, mscorlib ... failed (mscorlib.dll). I'm about to do some searching to see why.
Active Contributor
cadmaxza
Message 5 of 7 (141 Views)
02-01-2006 05:47 AM in reply to: cadmaxza
File permission problem solved! Havent checked the SQL connection yet though. Here are the details on how to solve:
Find mscorcfg.msc and run it. Then expand as follows:
Runtime Security Policy
- Machine
- Code Groups
- All_Code
Highlight LocalIntranet under All_Code, right click and choose Properties.
Go to the Permission Set tab and choose Full Control.
Active Contributor
cadmaxza
Message 6 of 7 (141 Views)
02-01-2006 05:57 AM in reply to: cadmaxza
Bingo!!! SQL connection error message solved... now to figure out why there's no data in the controls.... :-(
New Member
krishnaeng
Message 7 of 7 (141 Views)
01-09-2008 09:47 PM in reply to: cadmaxza
Request for the permission of type 'System.Data.SqlClient.SqlClientPermission, System.Data, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089' failed.
this error occur even setting the Permission to FullTrust which is availabel in the permission tab
Help me out
Post to the Community
New Post
Announcements
Do you have 60 seconds to spare? The Autodesk Community Team is revamping our site ranking system and we want your feedback! Please click here to launch the 5 question survey. As always your input is greatly appreciated.
