.NET
SQL Connection problem
6 REPLIES 6
384 Views, 6 Replies
I have compiled a stand alone application that connects to our sql server and reads data from the tables, providing searches. I have also compiled the same code as a dll to be used as a command in AutoCAD. But the dll exits at the sql connection string.
The error message is:
Request for permission of type 'System.Data.SqlClient.SqlClientPermission, System.Data, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089' failed.
The connection string includes the following info:
Initial Catalog
Data Source
Packet Size
User Id
Password
Any ideas? Have I missed something? Why doesnt the dll connect but the exe does?
Kevin.
6 REPLIES 6
This has got to be a sql server security issue, I use jet 4.0 mdb files from dot net and use the same dll from an external exe and inside of ADT/Autocad as well with no problems.
My guess is that the exe correctly builds the proper client info to use sql server and the dll does not.
Chris Arps
Mikko
Just tried this with no problems.
Imports Autodesk.AutoCAD.Runtime
Public Class Class1
_
Public Sub AllUsers()
MsgBox(GetUsers().Tables(0).Rows(1).Item(0).ToString)
End Sub
Public Function GetUsers() As DataSet
Dim MyConnection As System.Data.SqlClient.SqlConnection = New System.Data.SqlClient.SqlConnection("server=sql-data;uid=YOUR_NAME;pwd=YOUR_PASSWORD;Trusted_Connection=false;database=WorkWithIt")
Dim MyCommand As System.Data.SqlClient.SqlDataAdapter = New System.Data.SqlClient.SqlDataAdapter("SELECT Email FROM Users", MyConnection)
Dim DS As DataSet = New DataSet
MyCommand.Fill(DS, "Users")
MyConnection.Close()
Return DS
End Function
End Class
Aha!! It is a security issue (still not solved though). I have just written my first VB.Net code to make a text file and I have encountered a similar error message ... System.Security.Permissions.FileIOPermission, mscorlib ... failed (mscorlib.dll). I'm about to do some searching to see why.
File permission problem solved! Havent checked the SQL connection yet though. Here are the details on how to solve:
Find mscorcfg.msc and run it. Then expand as follows:
Runtime Security Policy
- Machine
- Code Groups
- All_Code
Highlight LocalIntranet under All_Code, right click and choose Properties.
Go to the Permission Set tab and choose Full Control.
Bingo!!! SQL connection error message solved... now to figure out why there's no data in the controls.... 😞
Request for the permission of type 'System.Data.SqlClient.SqlClientPermission, System.Data, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089' failed.
this error occur even setting the Permission to FullTrust which is availabel in the permission tab
Help me out
”Boost
