.NET
Valued Contributor
bikelink
Message 1 of 5 (445 Views)
spline to pline API ?
445 Views, 4 Replies
10-25-2010 03:04 AM
i'm looking for the api to convert a spline to pline (autocad 2010 can do it with convert)
I hope exists also an api that we call to make it..
any idea ?
thanks in advance!
Distinguished Contributor
SEANT61
Message 2 of 5 (442 Views)
Re: spline to pline API ?
10-25-2010 03:14 AM in reply to: bikelink
There is the Spline.ToPolylineWithPrecision Method.
Valued Contributor
bikelink
Message 3 of 5 (431 Views)
10-25-2010 05:05 AM in reply to: bikelink
ok, for previous version this is not available.. some work around to make it possible also with 2009 ?
SEANT61
Message 4 of 5 (393 Views)
10-26-2010 01:53 AM in reply to: bikelink
How do you intend to recreate the path?  I suppose recreating the Spline’s path with arcs would be a bit difficult – short line segments, however, should be fairly easy.  If the spline’s total parameter (Interval)  were divide by the appropriate amount:
Double seg = (Spline.EndParam – Spline.StartParam) / 100;
For example, then a for loop could find successive position with Spline.GetPointAtParameter.  One characteristic of Splines is that the Interval naturally compresses at areas of high curvature so the chord height is kept to a minimal.
Valued Mentor
Jeffrey_H
Message 5 of 5 (379 Views)
10-26-2010 04:58 AM in reply to: SEANT61
Are you wanting to convert to a polyline to get a tighter bounding box?
If so like SEANT61 suggested  just add to check  the X and Y value and update some variable's value for X and Y min max value
You can also find your answers @ TheSwamp
