.NET
spline to pline API ?
4 REPLIES 4
bikelink
920 Views, 4 Replies
i'm looking for the api to convert a spline to pline (autocad 2010 can do it with convert)
I hope exists also an api that we call to make it..
any idea ?
thanks in advance!
4 REPLIES 4
SEANT61
in reply to: bikelink
There is the Spline.ToPolylineWithPrecision Method.
May your cursor always snap to the location intended.
bikelink
ok, for previous version this is not available.. some work around to make it possible also with 2009 ?
SEANT61
How do you intend to recreate the path?  I suppose recreating the Spline’s path with arcs would be a bit difficult – short line segments, however, should be fairly easy.  If the spline’s total parameter (Interval)  were divide by the appropriate amount:
Double seg = (Spline.EndParam – Spline.StartParam) / 100;
For example, then a for loop could find successive position with Spline.GetPointAtParameter.  One characteristic of Splines is that the Interval naturally compresses at areas of high curvature so the chord height is kept to a minimal.
Jeffrey_H
in reply to: SEANT61
Are you wanting to convert to a polyline to get a tighter bounding box?
If so like SEANT61 suggested  just add to check  the X and Y value and update some variable's value for X and Y min max value
You can also find your answers @ TheSwamp
”Boost
