.NET
Splash Screen in C#
15 REPLIES 15
Message 1 of 16
1153 Views, 15 Replies
Splash Screen in C#
Hi everyone!
Is it possible to create possible to create splash screen in C#.
How should i do?
Thanks in advance!
Aymen
15 REPLIES 15
Message 2 of 16
RonnieWilkins
http://www.google.com/search?hl=en&q=splash+screen+site%3Awww.codeproject.com
Ronnie Wilkins, Jr.
Message 3 of 16
Thanks rwilkins,
The problem is that i have already seen some of these examples. In fact i have to be more precise :
i would like to show my splash screen when the dll is loaded in autocad, i have already created the necesary display functions but i don't know how to implement it. I wonder if there is an equivalent in C# to the C++ void initApp(){}...
Sorry for my english and thanks in advance for anyone who can help.
Aymen,
Message 4 of 16
Sorry I meant an equivalent to kInitAppMsg...
Message 5 of 16
You could use the IExtensionApplication Interface which is called
when your app is loaded and unloaded. Whether or not this is a
good idea with a timed form is another thing. Maybe someone will
let us know.
wrote in message news:5317804@discussion.autodesk.com...
Thanks rwilkins,
initApp(){}...
Aymen,
Message 6 of 16
Here is a sample of implementing this interface.
Someone please chime in if this is not the right way
to approach this.
[code]
public class LoadUnload : IExtensionApplication
#region IExtensionApplication Members
public void Initialize()
Application.DocumentManager.MdiActiveDocument.
Editor.WriteMessage("I just loaded");
public void Terminate()
//no NetUnload
#endregion
[/code]
"Paul Richardson" wrote in message
news:5317832@discussion.autodesk.com...
let us know.
Thanks rwilkins,
initApp(){}...
Aymen,
Message 7 of 16
Thanks Paul! It seems to be a good idea, i'm trying it... I'll tell you if it works.
Aymen
Message 8 of 16
Quite amazing, I didn't see your last post, I was trying the same code you wrote and... it works for me. Now, I have to find a way to show the splash screen...
Aymen
This is the working code:
using Autodesk.AutoCAD.Runtime;
using Autodesk.AutoCAD.ApplicationServices;
using Autodesk.AutoCAD.EditorInput;
using Autodesk.AutoCAD.GraphicsInterface;
[assembly: CommandClass(typeof(TempProject.SplashScreenProject))]
namespace TempProject
public class Class1 : Autodesk.AutoCAD.Runtime.IExtensionApplication
//Code to run when the program is loaded
Editor ed = Application.DocumentManager.MdiActiveDocument.Editor;
ed.WriteMessage("Loading...Showing a splash screen project");
Application.ShowAlertDialog("Should be a splash sceen instead!");
#endregion
public class SplashScreenProject
[CommandMethod("spl-command")]
static public void splash()
ed.WriteMessage("\nInvoking a command...");
Message 9 of 16
You don't need a command this will be called automatically
when your app is loaded.
I assume just calling your method to show the splash in the
initialize member should do it.
wrote in message news:5317979@discussion.autodesk.com...
screen...
Aymen
Editor ed =
instead!");
#endregion
Editor ed =
Message 10 of 16
Yes I know, the command added was only for my personal use... When I said it works I meant that the messageBox appeared in the screen and "Loading...Showing a splash screen project" was displayed in the command line.
Aymen,
Message 11 of 16
It was more for any others viewing the post... 🙂
wrote in message news:5318018@discussion.autodesk.com...
line.
Aymen,
Message 12 of 16
Check out Lab6. There is a sample that does multiple things at startup,
so I guess it's ok. Dump them all into a single file and you have a
nice searchable reference.
news:5318110@discussion.autodesk.com...
line.
Aymen,
Message 13 of 16
Thanks Paul!
Ok, this is what i exactly did, it works perfectly. 😉
Now, my problem is that i would like to make my splash screen disappear after 3 seconds...i'm exploring example codes.
Aymen,
Message 14 of 16
I found this in the net :
http://arxdummies.blogspot.com/2006/05/transparent-splash-screen.html
it is in C++, i'm trying to understand it...
Aymen,
Message 15 of 16
Hi all,
...And the solution was to insert a timer from the toolbox and the code added in the region Windows form would be :
private void InitializeComponent()
///some code here
this.timer1 = new System.Windows.Forms.Timer(this.components);
///perhaps some code here
this.timer1.Enabled = true; //acvtivate the timer
this.timer1.Interval = 3000; //setting the event notification interval to 3 seconds
this.timer1.Tick += new System.EventHandler(this.timer1_Tick); //Event handler and associated void
///some code here
And the editor will ask you to add this :
void timer1_Tick(object sender, EventArgs e)
//The two lines that follow are added by the user
timer1.Stop(); //Stop the timer
this.Close();//Close the form
Ok, that's all for today!
I hope that it is enough clear, unfortunately my english doesn't allow me to explain more.
Thank you Paul for your help.
Aymen,
Message 16 of 16
check this out.
http://through-the-interface.typepad.com/
wrote in message news:5317104@discussion.autodesk.com...
Hi everyone!
How should i do?
Thanks in advance!
Aymen
”Boost
