i do not completely understand the problem, but might i suggest using a selection filter, and then filtering out all the things that you don't want so that you are left with what you do want - you can then perform the operation then.
i am a noob myself, but perhaps the above is helpful?
Might this be of any help:
SelectionFilter regionFilter=new SelectionFilter(new TypedValue[]{new TypedValue((int)DxfCode.Start, "REGION")});
var selRegResult=ed.SelectAll(regionFilter);
if (selRegResult.Status != PromptStatus.OK)
return;
var regionIds = selRegResult.Value.GetObjectIds();
//DBObjectCollection regions = new DBObjectCollection();
//Order by Area, largest first. MUST be all Region ObjectIds
var largestRegionIds = selRegResult.Value.GetObjectIds().Cast<dynamic>().OrderByDescending(r => r.Area);
//var largestRegions=regions.Cast<Autodesk.AutoCAD.DatabaseServices.Region>().OrderByDescending(r => r.Area);
//Take the first 6 only (or less)
var largest6RegionIds = selRegResult.Value.GetObjectIds().Cast<dynamic>().OrderByDescending(r => r.Area).Take(6);
//var largest6Regions = regions.Cast<Autodesk.AutoCAD.DatabaseServices.Region>().OrderByDescending(r => r.Area).Take(6);
largest6RegionIds.ToList().ForEach(r => ed.WriteMessage("\n Area={0}, Handle={1}", r.Area, r.Handle));
//largest6Regions.ToList().ForEach(r => ed.WriteMessage("\n Area={0}, Handle={1}", r.Area, r.Handle));
And if you still want to have access to the Region objects without the Explode, then this modified version of: Philippe Leefsma
(http://adndevblog.typepad.com/autocad/2012/07/accessing-sub-entities-using-assocperssubentityidpe-in... might help as well
using (Transaction tr = db.TransactionManager.StartTransaction()) { var largestRegion = (Autodesk.AutoCAD.DatabaseServices.Region)tr.GetObject(largest6RegionIds.First(), OpenMode.ForRead); IntPtr pSubentityIdPE = largestRegion.QueryX(AssocPersSubentityIdPE.GetClass(typeof(AssocPersSubentityIdPE))); if (pSubentityIdPE == IntPtr.Zero) return; AssocPersSubentityIdPE subentityIdPE = AssocPersSubentityIdPE.Create(pSubentityIdPE, false) as AssocPersSubentityIdPE; ObjectId[] regionIdAsArray = new ObjectId[] { largestRegion.ObjectId }; SubentityId[] edgeIds = subentityIdPE.GetAllSubentities(largestRegion, SubentityType.Edge); ed.WriteMessage("\n Largest Region: Area={0}, Handle={1} Edges: ", largestRegion.Area, largestRegion.Handle); foreach (SubentityId subentId in edgeIds) { FullSubentityPath sePath = new FullSubentityPath(regionIdAsArray, subentId); using (Entity edgeEntity = largestRegion.GetSubentity(sePath)) { //SubEntity.Objectid==0 ed.WriteMessage("\n\t\t Type={0}, Handle={1}", edgeEntity.ObjectId.ObjectClass.DxfName, edgeEntity.Handle); var edge=edgeEntity as Curve; if (edge !=null) ed.WriteMessage("\n\t Edge Type={0}: ({1},{2})..({3},{4})[OCS==WCS]",edge.GetRXClass().DxfName, (int)edge.StartPoint.X, (int)edge.StartPoint.Y, (int)edge.EndPoint.X, (int)edge.EndPoint.Y); //Line line = edge as Line; //if (line != null) // ... } } tr.Commit(); }
Sample results:
Command: TESTREGIONS
Area=7761017.86352489, Handle=28A
Area=4721276.38892092, Handle=28C
Area=2858533.41794501, Handle=28B
Area=1053332.21028311, Handle=239
Area=822640.105885869, Handle=236
Area=412343.241778572, Handle=235
Largest Region: Area=7761017.86352489, Handle=28A Edges:
Edge Type=LINE: (7682,2672)..(11590,2672)[OCS==WCS]
Edge Type=LINE: (7682,686)..(7682,2672)[OCS==WCS]
Edge Type=LINE: (11590,686)..(7682,686)[OCS==WCS]
Edge Type=LINE: (11590,2672)..(11590,686)[OCS==WCS]
