.NET
some questions about Polyline and Polyline3d
2 REPLIES 2
535 Views, 2 Replies
I have some questions about Polyline and Polyline3d.
1. How to get Start/End point?
According to HELP I may Get and SET Start/End point from Curve class. Bat in fact I succeed only in Get, but not to Set. Duos it bug in wrappers?
2. How I Get number of vertices for Polyline3d (I tried to fined something like NumberOfVertices for Polyline)
3. How I can iterate throw vertices of Polyline3d from last vertex to first (I found GetEnumerator() and MoveNext(), but only in direction from start to end, But I need reverse from end to start).
Thank you for any help, source examples or references.
Emil
2 REPLIES 2
Try some of these:
plent = (ent)Polyline;
plent.EndParam();
plent.NumberOfVertices();
plent.GetDistanceAtParameter()
I think they will help.
Hugo
Try this, it works for me.
Public Shared Sub TestPline3d()
Dim editor As Editor = Application.DocumentManager.MdiActiveDocument.Editor
Dim db As Database = Application.DocumentManager.MdiActiveDocument.Database
Dim trans As Transaction = db.TransactionManager.StartTransaction()
Try
Dim prEnt As New PromptEntityOptions("Select a 3d polyline:")
Dim prEntRes As PromptEntityResult = editor.GetEntity(prEnt)
If prEntRes.Status <> PromptStatus.OK Then Return
Dim id As ObjectId = prEntRes.ObjectId
' get input polyline
Dim ent As Entity = DirectCast(trans.GetObject(id, OpenMode.ForRead), Entity)
Dim pl As Polyline3d = DirectCast(ent, Polyline3d)
Dim c As Curve = DirectCast(pl, Curve)
' the magic trick is first line segment on 3dpoly is 0.0 to 1.0,
' 2nd line seg is 1.0 to 2.0, rinse and repeat
Dim sp As Double = c.StartParam
Dim ep As Double = c.EndParam
Dim outPts As String
Dim p As Double
For p = sp To ep Step 1.0
Dim pt As Point3d = c.GetPointAtParameter(p)
outPts &= String.Format(" {0},{1},{2} ", pt.X, pt.Y, pt.Z) & vbCrLf
Next
MsgBox(outPts)
trans.Commit()
Catch ex As Exception
trans.Abort()
MsgBox(ex.Message)
Finally
trans.Dispose()
End Try
End Sub
You cannot set information using the curve interface, it looks like you will have to define a new Polyline3d and add it to the database instead.
Chris Arps Message was edited by: CArps
”Boost
