.NET
Valued Contributor
hoathuongphuoc
Message 1 of 2 (190 Views)
Accepted Solution
Some mistake when change UCS
190 Views, 1 Replies
12-16-2013 06:37 PM
Hi All,
I have one question in forum about UCS. My topic still related to UCS. This is, When i changed UCS the first time, its ok. But When i changed it second time or more. My ucs have some mistake. Hope everybody can understand my question. Thanks very much. And this is my code.
 <CommandMethod("ROTZ")> _
Public Sub NewUCS()
Try
Dim result As PromptPointResult
Dim mat As Matrix3d
''get the current document and database
Dim doc As Document = Application.DocumentManager.MdiActiveDocument
doc.LockDocument()
Dim db As Database = doc.Database
Dim ed As Editor = doc.Editor
''inform user click point
Dim ptpoint As New PromptPointOptions("")
''set current user coordinate system
ptpoint.Message = vbLf & "Choose start Point:"
result = ed.GetPoint(ptpoint)
If (result.Status <> PromptStatus.OK) Then
Return
Dim pt1 As Point3d = result.Value
ptpoint.Message = vbLf & "Choose end Point"
Dim pt2 As Point3d = result.Value
Dim zAxis As Vector3d = ed.CurrentUserCoordinateSystem.CoordinateSystem3d.Zaxis
Dim xAxis As Vector3d = pt1.GetVectorTo(pt2)
Dim yAxis As Vector3d = xAxis.GetPerpendicularVector
mat = Matrix3d.AlignCoordinateSystem(Point3d.Origin, Vector3d.XAxis, Vector3d.YAxis, Vector3d.ZAxis, pt1, xAxis, yAxis, zAxis)
ed.CurrentUserCoordinateSystem = mat
Catch ex As System.Exception
End Try
End Sub
Points returnd by Editor.GetPoint() are defined in the current system coordinates. you have to transform them to WCS before using them to build a new UCS.
Dim ucs As Matrix3d = ed.CurrentUserCoordinateSystem
pt1 = pt1.TransformBy(ucs)
pt2 = pt2.TransformBy(ucs)
Dim zAxis As Vector3d = ucs.CoordinateSystem3d.Zaxis
Dim yAxis As Vector3d = zAxis.CrossProduct(xAxis)
ed.CurrentUserCoordinateSystem = Matrix3d.AlignCoordinateSystem( _
Point3d.Origin, Vector3d.XAxis, Vector3d.YAxis, Vector3d.ZAxis, _
*Expert Elite*
_gile
Message 2 of 2 (169 Views)
Re : Some mistake when change UCS
12-17-2013 12:20 AM in reply to: hoathuongphuoc
Gilles Chanteau
Announcements
Need installation help?
