.NET
Some mistake when change UCS
1 REPLY 1
548 Views, 1 Reply
Hi All,
I have one question in forum about UCS. My topic still related to UCS. This is, When i changed UCS the first time, its ok. But When i changed it second time or more. My ucs have some mistake. Hope everybody can understand my question. Thanks very much. And this is my code.
 <CommandMethod("ROTZ")> _
Public Sub NewUCS()
Try
Dim result As PromptPointResult
Dim mat As Matrix3d
''get the current document and database
Dim doc As Document = Application.DocumentManager.MdiActiveDocument
doc.LockDocument()
Dim db As Database = doc.Database
Dim ed As Editor = doc.Editor
''inform user click point
Dim ptpoint As New PromptPointOptions("")
''set current user coordinate system
ptpoint.Message = vbLf & "Choose start Point:"
result = ed.GetPoint(ptpoint)
If (result.Status <> PromptStatus.OK) Then
Return
End If
Dim pt1 As Point3d = result.Value
ptpoint.Message = vbLf & "Choose end Point"
Dim pt2 As Point3d = result.Value
Dim zAxis As Vector3d = ed.CurrentUserCoordinateSystem.CoordinateSystem3d.Zaxis
Dim xAxis As Vector3d = pt1.GetVectorTo(pt2)
Dim yAxis As Vector3d = xAxis.GetPerpendicularVector
mat = Matrix3d.AlignCoordinateSystem(Point3d.Origin, Vector3d.XAxis, Vector3d.YAxis, Vector3d.ZAxis, pt1, xAxis, yAxis, zAxis)
ed.CurrentUserCoordinateSystem = mat
Catch ex As System.Exception
End Try
End Sub
1 REPLY 1
_gile
Points returnd by Editor.GetPoint() are defined in the current system coordinates. you have to transform them to WCS before using them to build a new UCS.
Dim ucs As Matrix3d = ed.CurrentUserCoordinateSystem
pt1 = pt1.TransformBy(ucs)
pt2 = pt2.TransformBy(ucs)
Dim zAxis As Vector3d = ucs.CoordinateSystem3d.Zaxis
Dim yAxis As Vector3d = zAxis.CrossProduct(xAxis)
ed.CurrentUserCoordinateSystem = Matrix3d.AlignCoordinateSystem( _
    Point3d.Origin, Vector3d.XAxis, Vector3d.YAxis, Vector3d.ZAxis, _
Gilles Chanteau
GileCAD
GitHub
”Boost
