.NET
Solutions to Insert Barcode in DWG using C#
10 REPLIES 10
Message 1 of 11
2091 Views, 10 Replies
Hello Everybody
Just looking out some options to insert Barcode / Barcode Image inside .dwg file using c#.
Please share your experience if anybody has ever worked on that.
Ashish...
10 REPLIES 10
Message 2 of 11
No one replied? Ok. I happen to read this post which is the topic I am interested in. I have experience of creating barcode in C# ASP.NET. At that time, I used that third party control. Nowadays, I think the easily way to create barcode is to use a third party control. You just need to install that tool into your program and then follow the guides of barcode creation, like this barcode data encoding guide in C#. So barcode creation becomes very easy.
Message 3 of 11
augusto.goncalves
Some time ago I did a implementation with Hatch and QR Code, you can get the source code at http://labs.autodesk.com/utilities/qrcodes/
One additional point, not implemented on the sample above, was to insert the Hatch as a Block, so the user cannot modify it by accident.
Augusto Goncalves
Twitter @augustomaia
Autodesk Developer Network
Message 4 of 11
Barcodes can be as simple as using a font.  QR codes are significantly more complex.
If you are going to fly by the seat of your pants, expect friction burns.
"I don't know" is the beginning of knowledge, not the end.
Message 5 of 11
in reply to: dgorsman
Yes, creating barcode in C# is quite easy with a barcode font. But I think QR Code is not that complex. QR Code is the most commonly used type of barcode.
Message 6 of 11
makaveiljojo
Check the sample code of how to generate barcode with C# and insert into document:
C# Sample code
     using KeepAutomation.Barcode.Bean;
BarCode barcode = new BarCode();
barcode.Symbology = KeepAutomation.Barcode.Symbology.Code39;
barcode.CodeToEncode = "111222333";
barcode.ChecksumEnabled = true;
barcode.X = 1;
barcode.Y = 50;
barcode.BarCodeWidth = 100;
barcode.BarCodeHeight = 70;
barcode.Orientation = KeepAutomation.Barcode.Orientation.Degree90;
barcode.BarcodeUnit = KeepAutomation.Barcode.BarcodeUnit.Pixel;
barcode.DPI = 72;
barcode.ImageFormat = System.Drawing.Imaging.ImageFormat.Gif;
barcode.generateBarcodeToImageFile("C://barcode-code39-csharp.gif");
/* Output barcode images to different objects
barcode.generateBarcodeToStream("Stream Object");
barcode.generateBarcodeToGraphics("Graphics Object");
barcode.generateBarcodeToGraphics("HttpResponse Object");
Message 7 of 11
cindy313
why so ?
Message 8 of 11
dgorsman
in reply to: cindy313
http://en.wikipedia.org/wiki/QR_code
Now, try building one.  Don't forget the mask.  🙂
Message 9 of 11
mindylynn0
As i know, barcode font can be used for barcode application, also available for QR Code barcode image. But 2d QR Code is a more complex barcode symbology among all common barcodes.
Message 10 of 11
andyadams
Hi,you said you have experience of creating barcode in C# ASP.NET and you used that third party control. However,i don't want to pay for that software,do you have some better ideal of creating barcode in C# ASP.NET???Cat Happy
Message 11 of 11
Keith.Brown
in reply to: andyadams
Not sure if this is what you want but here is a free solution.
http://www.codeproject.com/Articles/20823/Barcode-Image-Generation-Library
”Boost
