.NET
Solid3d properties
8 REPLIES 8
Message 1 of 9
Fredrik.Larsen
1839 Views, 8 Replies
Solid3d properties
Hi
Is there a way to get the type of the Solid3d object and its parameters?
E.g. Type = Box, Height = 100, Width = 200, Length = 100 (Or something like that)
8 REPLIES 8
Message 2 of 9
sszabo
in reply to: Fredrik.Larsen
The following code will find solids in your drawing and dump all its properties.  The pros are that you can use this method to learn about any autocad object, the cons that you will have to come up with a more robust way to dump them other than ed.WriteMessage because the Editor buffer is simply not large enough to print out all the properties of a complex autocad object. I usually use NLog for this purpose.
        Imports MgdAcApplication = Autodesk.AutoCAD.ApplicationServices.Application
        <CommandMethod("myMacros", "dumpSolids", Nothing, CommandFlags.Modal)> _
        Public Sub dumpSolids_Method()
            Try
                Dim activeDoc As Document = MgdAcApplication.DocumentManager.MdiActiveDocument
                Dim ed As Editor = activeDoc.Editor
                Dim db As Database = HostApplicationServices.WorkingDatabase
                Using tr As Transaction = db.TransactionManager.StartTransaction()
                    For i As Long = db.BlockTableId.Handle.Value To db.Handseed.Value - 1
                        Dim id As ObjectId = ObjectId.Null
                        Dim h As New Handle(i)
                        If db.TryGetObjectId(h, id) Then
                            If id.ObjectClass.Name = "AcDb3dSolid" Then
                                Dim ent As Entity = CType(tr.GetObject(id, OpenMode.ForRead, True), Entity)
                                For Each p As System.Reflection.PropertyInfo In ent.GetType().GetProperties()
                                    Try
                                        Dim displStr As String = String.Format("  {0}:     '{1}'", p.Name, p.GetValue(ent, Nothing))
                                        ed.WriteMessage(vbLf + displStr)
                                    Catch
                                        ed.WriteMessage(vbLf + "EX 1. " + Err.GetException.ToString)
                                    End Try
                                Next
                            End If
                        End If
                    Next
                End Using
            Catch
                ed.WriteMessage(vbLf + "EX 2. " + Err.GetException.ToString)
            End Try
        End Sub
Message 3 of 9
DiningPhilosopher
in reply to: sszabo
@sszabo wrote:
The following code will find solids in your drawing and dump all its properties.  The pros are that you can use this method to learn about any autocad object, the cons that you will have to come up with a more robust way to dump them other than ed.WriteMessage because the Editor buffer is simply not large enough to print out all the properties of a complex autocad object. I usually use NLog for this purpose....
I'm afraid this isn't going to help the OP, because solid history properties (like Cyilinder height/radious) are not exposed via any API. There are no managed wrapper properties for them, and for that matter, there are no managed wrapper types for the various primitives (Cylinder, Box, Cone, etc.).
The fact that the OP's question has been ignored by Autodesk personell is also not suprising, as Autodesk has very deliberately witheld basic scripting functionality for 3D solid primitives from their $4K 3D CADD software, and is most-likely a topic which most of them are not permitted to discuss.
Message 4 of 9
Balaji_Ram
Hi Fredrik / DP,
Yes, It would have been easier if there were independent classes representing the different kinds of solids.
There may be some design considerations for the way the class hierarchy is, which I am unaware of.
But at present, "AcDb3dSolid" is a class that represents different kinds of 3d solids and I think it is the same even with the C++ API.
Here is blog post that might help get the properties directly using OPM interfaces :
http://adndevblog.typepad.com/autocad/2012/05/how-to-obtain-acdb3dsolid-opm-properties-in-autocad-us...
It is a C++ code but you can use it in a mixed managed project which can then be referenced in your managed project.
Balaji
Developer Technical Services
Autodesk Developer Network
Message 5 of 9
HI Belaji.
The 'internal-use-only' classes for history-based Solid primitives all have identifiers starting with AcDbSh*
Here is a small excerpt from an exports dump of acdbxx.dll (showing only the exports for the class that represents a Cylinder).
AcDbShCylinder::AcDbShCylinder(class AcDbSystemInternals *)
AcDbShCylinder::AcDbShCylinder(void)
class AcRxClass * AcDbShCylinder::desc(void)
class AcRxClass * AcDbShCylinder::gpDesc
double AcDbShCylinder::height(void)
class AcRxClass * AcDbShCylinder::isA(void)
bool AcDbShCylinder::isCylindrical(void)
bool AcDbShCylinder::isElliptical(void)
double AcDbShCylinder::majorRadius(void)
double AcDbShCylinder::minorRadius(void)
enum Acad::ErrorStatus AcDbShCylinder::setHeight(double)
enum Acad::ErrorStatus AcDbShCylinder::setMajorRadius(double)
enum Acad::ErrorStatus AcDbShCylinder::setMinorRadius(double)
enum Acad::ErrorStatus AcDbShCylinder::setXRadius(double)
enum Acad::ErrorStatus AcDbShCylinder::setYRadius(double)
double AcDbShCylinder::xRadius(void)
double AcDbShCylinder::yRadius(void)
AcDbShCylinder::~AcDbShCylinder(void)
Message 6 of 9
_gile
Maybe you can use the Brep class (Boundary Representation) and get these infos from the edges.
See a simple example here:
http://www.theswamp.org/index.php?topic=31865.msg445372#msg445372
Gilles Chanteau
GileCAD
GitHub
Message 7 of 9
Fredrik.Larsen
in reply to: _gile
I have tested the boundary representation example. Is there a good way to interpret and recognize something using this? I understand that this may be difficult since a solid3d can have any shape.
I have also looked at Fenton Webbs ObjectARX example linked in this post. I have only used .NET API so I haven't been able to run it, but I see he gets height, length and width. Is it possible to get the type of primitive as well since this is shown in the properties in AutoCAD? (See attached image)
Message 8 of 9
* get type of solid
Message 9 of 9
No, as I mentioned in a previous reply, the classes that represent Solid3d primitives with history are not publicly usable, and there are no other ways short of DXF-style hacking using acdbEntGet()/acdbEntMod() to manipulate or access the primitives and their properites.
This is by design
”Boost
