.NET
Slowing down when changing Block Reference Property Values
1 REPLY 1
343 Views, 1 Reply
I'm inserting automatically many references to a couple of dynamic blocks in an AutoCAD drawing using VB.NET. If the number of inserted references is not very big, it works fine but, if I´m inserting hundreds of them, I noticed the app is slowing down a lot.
After taking some measures of the time the app uses in its execution, I noticed changing the value of the block reference property is slower as the number of inserted block increases: it takes 10 or 20 miliseconds at the begining but it can take more than 1 second after inserting one thousand of block references (to the same block).
This is the function I use to change the property values:
Protected Sub CambiarPropiedades(ByRef ed As Editor, _
                                 ByRef br As BlockReference, _
                                 ByVal nombrePropiedad As String, _
                                 ByVal valor As Double)
    Dim pc As DynamicBlockReferencePropertyCollection = br.DynamicBlockReferencePropertyCollection
    If br IsNot Nothing And br.IsDynamicBlock Then
      For Each prop As DynamicBlockReferenceProperty In pc
        If prop.PropertyName = nombrePropiedad Then
          prop.Value = valor  ' This line takes a long time the first time I call this function for the
                              ' same block reference but it is faster in the next calls
                              ' It also changes the block reference name (br.name) in the first call
          Exit For
        End If
      Next
    End If
  End Sub
 Which I call to change all the properties I need to change in an inserted block reference:
      CambiarPropiedades(ed, br, "h_testua", objElementoLaboratorio.POS_TEXTO)
      CambiarPropiedades(ed, br, "d_texto_hor", posxTexto)
      CambiarPropiedades(ed, br, "largo", objElementoLaboratorio.LARGO)
      CambiarPropiedades(ed, br, "fondo", objElementoLaboratorio.FONDO)
 A weird thing I noticed is that when I call this function to change the first property of an inserted block, it also changes the .Name of the block reference.
Even if I change the order in the property modification, it takes always a lot in the first call, it does not depend on the property I´m changing.
Any clue of what is going on?
Thanks a lot.
Andoni
1 REPLY 1
hgasty1001
As for the performance issue , it seems we have to live with it, see this thread in the Swamp: DynBlocks Performance , as for the .Name change it's by design as a DynamicBlock change its name to anomymous block when some dynamic property is changed or activate , after that you need to check the effective name of the block reference, you can implement this "property" as an extension method (Extensions) or a simple function like this:
Public Function GetEffectiveName(ByVal blkref As BlockReference, ByVal acTrans As Transaction) As String
        Dim btr As BlockTableRecord
        btr = acTrans.GetObject(blkref.DynamicBlockTableRecord, OpenMode.ForRead)
        Return btr.Name
End Function
Gaston Nunez
”Boost
