.NET
Valued Mentor
fieldguy
Message 1 of 6 (481 Views)
Simulate CommandFlags.Session from form button
481 Views, 5 Replies
05-10-2012 02:10 PM
I am working on an application that uses map to query data, then saves the data to a file, and repeat.  It works flawlessly when I use a commandmethod with commandflags.session, But, when I try to run the same code from a form button, I get "drawing is busy".  The command from the form button ignores the commandmethod and the commandflags.  I am guessing that "sendstringtoexecute" would work, but I would prefer to not do it that way.
What am I missing?  Is there another way to lock the session?
Here is what I am trying to do.
drawing1 is open and the user presses the button
data is queried and saved as 1.dwg
close and discard drawing1
open a new doc drawing2
data is queried and saved as 2.dwg
close and discard drawing2
open a new doc drawing3
You can try using DocumentCollection.ExecuteInApplicationContext method.
Moderator
Alexander.Rivilis
Message 2 of 6 (477 Views)
Re: Simulate CommandFlags.Session from form button
05-10-2012 02:29 PM in reply to: fieldguy
Пожалуйста не забывайте про Утвердить в качестве решения! Утвердить в качестве решения и Give Kudos!Баллы
Please remember to Accept Solution! Accept as Solution and Give Kudos!Kudos
Valued Mentor
fieldguy
Message 3 of 6 (462 Views)
05-10-2012 03:33 PM in reply to: Alexander.Rivilis
That's even better - thank you.  Starting at an empty drawing1, the user presses the button, and the queries start in drawing2.  When it's finished, the user is back at an empty drawing1.
Hallex
Message 4 of 6 (440 Views)
05-11-2012 01:20 AM in reply to: fieldguy
Show your code, please,
~'J'~
Valued Mentor
fieldguy
Message 5 of 6 (425 Views)
05-11-2012 08:16 AM in reply to: Hallex
Good idea - sorry.  It took a bit of digging and I was in a rush.  Thanks again Alexander and tony t (again and again...).
 <CommandMethod("q19")> _
    Sub q_19()
        Dim acdocmgr As acapp.DocumentCollection = acapp.Application.DocumentManager
        'assume drawing1 is active - it does not matter
        acdocmgr.ExecuteInApplicationContext(AddressOf testsub, Nothing)
    End Sub
    Private Sub testsub(ByVal data As Object)
        'in this example data is not used
        Dim cmddiavalue As Integer = CInt(acapp.Application.GetSystemVariable("CMDDIA"))
        acapp.Application.SetSystemVariable("CMDDIA", 0)
        Dim acdoc As acapp.Document = acdocmgr.MdiActiveDocument
        Dim templatepath As String = "map2diso.dwt"
        acdoc = acdocmgr.Add(templatepath)
        acdocmgr.MdiActiveDocument = acdoc
        'drawing2 is now active
        Using acdoclock As acapp.DocumentLock = acdoc.LockDocument
            Dim currentobjs As New ObjectIdCollection()
            'query and save
        End Using
        acdoc.CloseAndDiscard()
        'drawing3
            'query and save
        End Using
        acapp.Application.SetSystemVariable("CMDDIA", cmddiavalue)
        Autodesk.AutoCAD.Internal.Utils.PostCommandPrompt()
        'return to drawing1 or whatever doc was before
    End Sub
Hallex
Message 6 of 6 (415 Views)
05-11-2012 11:27 AM in reply to: fieldguy
Thanks for sharing your code
Oleg
