.NET
Simulate CommandFlags.Session from form button
5 REPLIES 5
fieldguy
976 Views, 5 Replies
I am working on an application that uses map to query data, then saves the data to a file, and repeat.  It works flawlessly when I use a commandmethod with commandflags.session, But, when I try to run the same code from a form button, I get "drawing is busy".  The command from the form button ignores the commandmethod and the commandflags.  I am guessing that "sendstringtoexecute" would work, but I would prefer to not do it that way.
What am I missing?  Is there another way to lock the session?
Here is what I am trying to do.
drawing1 is open and the user presses the button
data is queried and saved as 1.dwg
close and discard drawing1
open a new doc drawing2
data is queried and saved as 2.dwg
close and discard drawing2
open a new doc drawing3
5 REPLIES 5
You can try using DocumentCollection.ExecuteInApplicationContext method.
Facebook | Twitter | LinkedIn
Expert Elite Member
That's even better - thank you.  Starting at an empty drawing1, the user presses the button, and the queries start in drawing2.  When it's finished, the user is back at an empty drawing1.
Hallex
in reply to: fieldguy
Show your code, please,
~'J'~
fieldguy
in reply to: Hallex
Good idea - sorry.  It took a bit of digging and I was in a rush.  Thanks again Alexander and tony t (again and again...).
 <CommandMethod("q19")> _
    Sub q_19()
        Dim acdocmgr As acapp.DocumentCollection = acapp.Application.DocumentManager
        'assume drawing1 is active - it does not matter
        acdocmgr.ExecuteInApplicationContext(AddressOf testsub, Nothing)
    End Sub
    Private Sub testsub(ByVal data As Object)
        'in this example data is not used
        Dim cmddiavalue As Integer = CInt(acapp.Application.GetSystemVariable("CMDDIA"))
        acapp.Application.SetSystemVariable("CMDDIA", 0)
        Dim acdoc As acapp.Document = acdocmgr.MdiActiveDocument
        Dim templatepath As String = "map2diso.dwt"
        acdoc = acdocmgr.Add(templatepath)
        acdocmgr.MdiActiveDocument = acdoc
        'drawing2 is now active
        Using acdoclock As acapp.DocumentLock = acdoc.LockDocument
            Dim currentobjs As New ObjectIdCollection()
            'query and save
        End Using
        acdoc.CloseAndDiscard()
        'drawing3
            'query and save
        End Using
        acapp.Application.SetSystemVariable("CMDDIA", cmddiavalue)
        Autodesk.AutoCAD.Internal.Utils.PostCommandPrompt()
        'return to drawing1 or whatever doc was before
    End Sub
Hallex
Thanks for sharing your code
Oleg
”Boost
