Do I have to change the version to 3.5?
If I do that will it get ride of my error message?
1>------ Build started: Project: lab 2014, Configuration: Release Any CPU ------
1>C:\Program Files (x86)\MSBuild\12.0\bin\Microsoft.Common.CurrentVersion.targets(1635,5): warning MSB3270: There was a mismatch between the processor architecture of the project being built "MSIL" and the processor architecture of the reference "accoremgd", "AMD64". This mismatch may cause runtime failures. Please consider changing the targeted processor architecture of your project through the Configuration Manager so as to align the processor architectures between your project and references, or take a dependency on references with a processor architecture that matches the targeted processor architecture of your project.
1> lab 2014 -> C:\test\lab 2014\lab 2014\bin\Release\lab 2014.dll
========== Build: 1 succeeded, 0 failed, 0 up-to-date, 0 skipped ==========
Solved by Keith.Brown. Go to Solution.
I also keep getting a error that says
A project with an Output Type of Class Libary cannot be started
directly.
In order to debug this project, add an executable project to this solution
which references the libary project. Set the executable project as the
startup project.
It would be nice if any one could tell me what is going wrong and how I could fix it.
You get that error because you are compiling for Any CPU when your processer is either a x86 or a AMD64. It cannot be both. You are probably safe to keep it at ANY CPU as long as you are not accessing any architecture specific DLL's. If you want to keep it at ANY CPU then you can supress the warning by adding the following lines to your .csproj or .vbproj files.
<PropertyGroup> <ResolveAssemblyWarnOrErrorOnTargetArchitectureMismatch> None </ResolveAssemblyWarnOrErrorOnTargetArchitectureMismatch> </PropertyGroup>
HTHs
attempted code below
using System; using System.Collections.Generic; using System.Linq; using System.Text; using System.Threading.Tasks; using Autodesk.AutoCAD.Runtime; using Autodesk.AutoCAD.ApplicationServices; using Autodesk.AutoCAD.DatabaseServices; using Autodesk.AutoCAD.Geometry; using Autodesk.AutoCAD.EditorInput; [assembly: CommandClass(typeof(lab_2014.Class1))] namespace lab_2014 { public class Class1 { [CommandMethod("FeetToInches")] public void Main() { Console.Write(FeetToInches(30)); Console.Write(FeetToInches(100)); } static int FeetToInches (int feet) { int inches = feet * 12; return inches; } } }
directly.
startup project.
Since you are creating a DLL file and not an executable you need to let Visual Studio know what executable should be ran with your DLL file. You can do this in the project properties by choosing AutoCAD as your external program.
I believe if you have an express version then you will not be able to set it using this method but will instead have to manuall set the executable in your project user file. You can read about it here.
