.NET
Active Member
nklong
Message 1 of 6 (223 Views)
ShowModelessDialog problem
223 Views, 5 Replies
05-21-2013 12:49 AM
I showed a form with ShowModelessDialog in this way:
MyForm fr = new  MyForm();
Application.ShowModelessDialog(null, fr, true);
But when I use this.Hide() in control event, It usually jump to another window. AutoCAD is not active.
How to fix this, pls help.
Thanks.
mzakiralam
Message 2 of 6 (216 Views)
Re: ShowModelessDialog problem
05-21-2013 01:28 AM in reply to: nklong
Please try :
Application.ShowModelessDialog(null, fr, false);
Active Member
nklong
Message 3 of 6 (213 Views)
05-21-2013 01:40 AM in reply to: mzakiralam
Thank you so much. I already try your way, but still the same.
mzakiralam
Message 4 of 6 (205 Views)
05-21-2013 01:57 AM in reply to: nklong
I have just tried this way and it is working for me:
testfrm f_test = new testfrm();
Application.ShowModelessDialog(f_test);
Then put the below code in a button
this.Hide()
Active Member
nklong
Message 5 of 6 (191 Views)
05-21-2013 03:04 AM in reply to: mzakiralam
I don't know why. If my form is simple, it's corect. But if have a lot of thing in form. When call this.Hide() always jump to another window.
mzakiralam
Message 6 of 6 (169 Views)
05-21-2013 10:17 AM in reply to: nklong
Then I think that you should show your code otherwise nobody can help you. May be there is something wrong with your code. Please make sure that as your are using modeless dialog, so you should lock the document before you want to do something. otherwise it will create problem.
