.NET
Showing and hiding toolbars in AutoCAD 2014
4 REPLIES 4
Luigi71
683 Views, 4 Replies
Hello all,
I'm trying to writing some routines to control the visibility of my own toolbars.
Dim cs As CustomizationSection = New CustomizationSection(my_CuiFile, my_CuiName)
Dim tb As Autodesk.AutoCAD.Customization.Toolbar = cs.MenuGroup.Toolbars.FindToolbarWithName(my_ToolbarName)
tb.ToolbarVisible = ToolbarVisible.hide
After the last instruction the toolbar still stay visible.
Some suggestions are very appreciated.
Thankyou
Luigi
4 REPLIES 4
Luigi71
in reply to: Luigi71
Nobody out there? Smiley Sad
Balaji_Ram
Hi Luigi,
Sorry for the delay.
Since your code is changing the cui, it will need to be saved and cuix reloaded for the visibility to get updated.
You can try doing that as in this code snippet.
 [DllImport("accore.dll", CharSet = CharSet.Ansi, CallingConvention = CallingConvention.Cdecl, EntryPoint = "acedCmd")]
    private static extern int acedCmd(System.IntPtr vlist);
    [DllImport("accore.dll", CharSet = CharSet.Ansi, CallingConvention = CallingConvention.Cdecl, EntryPoint = "ads_queueexpr")]
    extern static int ads_queueexpr(byte[] command);
public void saveCui()
        // Save all Changes made to the CUI file in this session.
        // If changes were made to the Main CUI file - save it
        // If changes were made to teh Partial CUI files need to save them too
        if (cs.IsModified)
            cs.Save();
        for (int i = 0; i < numPartialFiles; i++)
            if (partials[i].IsModified)
                partials[i].Save();
        // Here we unload and reload the main CUI file so the changes to the CUI file could take effect immediately.
        // To do this we P/Invoke into acedCmd() in order to synchronously call the CUIUNLOAD / CUILOAD command, disarming and
        // rearming the file dialog during the process.
        ResultBuffer rb = new ResultBuffer();
        // RTSTR = 5005
        rb.Add(new TypedValue(5005, "FILEDIA"));
        rb.Add(new TypedValue(5005, "0"));
        // start the insert command
        acedCmd(rb.UnmanagedObject);
        string cuiFileName = cs.CUIFileBaseName;
        //CUIUNLOAD
        rb.Add(new TypedValue(5005, "_CUIUNLOAD"));
        rb.Add(new TypedValue(5005, cuiFileName));
        //CUILOAD
        rb.Add(new TypedValue(5005, "_CUILOAD"));
        //FILEDIA
        rb.Add(new TypedValue(5005, "1"));
 But I think it would be much simpler to show/hide toolbars simply by sending the commands as in these Lisp statements :
(command "toolbar" "Draw" "show")
(command "toolbar" "Draw" "hide")
Balaji
Balaji
Developer Technical Services
Autodesk Developer Network
Luigi71
in reply to: Balaji_Ram
Thankyou Balaji, I will try the suggestion and send a feedback as soon as possible.
Luigi71
Ok Balaji
as per your suggestion I tried  the lisp strings.
Briefly my need is to automatic load my custom cuix file and switching my toolbars depending what workspace is selected, the toolbars are to be displayed only in "AutoCAD Classic" display mode, so:
Namespace ManagedApplication
Public Class Initialization
Implements Autodesk.AutoCAD.Runtime.IExtensionApplication
Public Sub Initialize() Implements IExtensionApplication.Initialize
Const cuiname As String = "MY_CUINAME"
Dim cuifile As String = "C:\[...]\MY_CUIFILE.cuix"
Dim mGroup As AcadMenuGroup
Try 'Testing the presence of the cuix
   mGroup = Autodesk.AutoCAD.ApplicationServices.Application.MenuGroups.Item(cuiname)
Catch ex As System.Exception 'If not, the cuix is loaded
   Autodesk.AutoCAD.ApplicationServices.Application.LoadPartialMenu(cuifile)
End Try
So, for toggle ON/OFF the toolbar by switching from one workspace to another there are the two following routines:
Sub CmdEnded(ByVal sender As Object, ByVal e As Autodesk.AutoCAD.ApplicationServices.CommandEventArgs)
   Dim doc As Document = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument
   Select Case e.GlobalCommandName
   Case "RIBBONCLOSE"
     doc.SendStringToExecute("(command" & " ""_toolbar"" " & " ""my_ToolbarName"" " & " ""_hide"") ", False, False, True)
   Case "RIBBON"
   End Select
End Sub
Sub Application_SystemVariableChanged(ByVal sender As Object, ByVal e As _ Autodesk.AutoCAD.ApplicationServices.SystemVariableChangedEventArgs)
   Select Case e.Name
    Case "WSCURRENT"
     Select Case Autodesk.AutoCAD.ApplicationServices.Application.GetSystemVariable("RIBBONSTATE")
      Case 0
        doc.SendStringToExecute("(command" & " ""_toolbar"" " & " ""my_ToolbarName"" " & " ""_show"") ", False, False, True)
      Case 1
     End Select
   Case "RIBBONCLOSE"
   Case "RIBBON"
End Select
End Sub
End Class
End Namespace
I tested the routine and seems to work fine.
It's a good way to proceed, or there is another better one, or more elegant?
Thank you for help
Luigi
Tags (3)
”Boost
