.NET
Valued Contributor
1 Kudo
Post 1 of 4
Show/hide toolbars
412 Views, 3 Replies
03-24-2012 03:42 AM
I loaded a partial customization file by CUI dialog. I would like to programmatically hide / show the menus and toolbars, so when you restart AutoCAD to be permanently hidden or visible. Can anyone hint how to do it?
Active Contributor
0 Kudos
Post 2 of 4
Re: Show/hide toolbars
03-24-2012 04:27 AM in reply to: fsztuczny
Hi there,
this code works, but I have ran into problems when Windows 7 UAC is set to high:
If any one has a better way of doing this then I would be greatful also:
Imports Autodesk.AutoCAD.Runtime
Imports Autodesk.AutoCAD.ApplicationServices
Imports Autodesk.AutoCAD.Interop
Imports System.Environment
<Assembly: CommandClass(GetType(ToolbarCmds))>
Public Class ToolbarCmds
    <CommandMethod("MyMenusCuix")> _
    Public Sub LoadToolbars()
        Dim cuiname As String = "MyMenus"
        Dim cuifile As String = "C:\MyMenus.cuix"
        Dim mg As AcadMenuGroup
        Try
            'Attempt to access our menugroup
            mg = Application.MenuGroups.Item(cuiname)
        Catch ex As System.Exception
            'Failure simply means we need to load the CUI first
            Application.MenuGroups.Load(cuifile)
            'Cycle through the toobars, setting them to visible
            Dim i As Integer
            For i = 0 To mg.Toolbars.Count - 1
                mg.Toolbars.Item(i).Visible = True
            Next
        End Try
    End Sub
End Class
Martin.
http://www.designprosoftware.co.uk/
1,218 Kudos
Post 3 of 4
03-24-2012 04:28 AM in reply to: fsztuczny
...create/save two workspaces, one having your partial menues visible and the other workspace having them invisible ...?
- alfred -
Alfred NESWADBA
Valued Contributor
1 Kudo
Post 4 of 4
03-30-2012 12:42 PM in reply to: Alfred.NESWADBA
Thank you.
