Hi,all:
I want to generate the images for the blocks, I found a method of blcitablerecord, but the image is too small, and can not show out clearly.
Bitmap preview = btr.PreviewIcon;
you know in autocad there is a MSLIDE command, can make a .sld file which can show out clearly in a lisp programe, but in .net winform how to show the image clearly? or other method to solve it?
Solved by hgasty1001. Go to Solution.
Hi,Gasty:
thank you for your information. I tried Kean's code, but get a error, can not found the method 'CMLContentSearchPreviews'.
by the way, what's the new screen grab tool you use?
regards
swaywood
can any body help me?
I can not found the method of 'CMLContentSearchPreviews' in autocad2013 Autodesk.AutoCAD.Windows.Data namespace.
the following is kean's blog address.
Hi,jeff:
do you know autocad2014 match what VS and framework .net version?
it seem's .net 4.0 can not import 2014 version acmgd.dll for me.
I'm using VS 2013 now, but i don't remember problems with Autocad 2014 and .net 4.0 in VS 2010, are you sure you have the right SDK , reference from the include folder and set copy to local false?
Gaston Nunez
Hi,Gaston Nunez and Jeff:
Thank you so much!
I got the bigger and clearer pictures in autocad 2014.
but the dll can not netload in autocad 2013.
