.NET
Sheet set custom property field "TransmittalSetups"
13 REPLIES 13
Message 1 of 14
1127 Views, 13 Replies
Hello all,
Been a while since I asked a question here about sheet set objects, so I would like to ask a realy hard question.
The SheetSetObject has an inbuilt custom property called "TransmittalSetups", but the property has a different internal object structure compared to other CustomProperty
Ie:
[code]
Dim myPropEnum As IAcSmEnumProperty = myCPB.GetPropertyEnumerator
Dim myPropName As String = Nothing
Dim myPropValue As AcSmCustomPropertyValue = Nothing
myPropEnum.Next(myPropName, myPropValue)
[/code]
myPropName is a string, and in this instance it returns a value of "TransmittalSetups"
myPropValue.GetValue is a string, and it says "System.__ComObject" not a "value".
So my question is, how do identify this object, how to interigate it or assign it to its native object type.
I have tried to cast it to different IAcSmEnum types but without success.
Thanks.
13 REPLIES 13
Message 2 of 14
fenton.webb
we don't expose the COM API for the eTransmittal setup object. What do you need to do exactly?
Fenton Webb
AutoCAD Engineering
Message 3 of 14
in reply to: fenton.webb
I have a routine the "resets" the custom properties in the sheet, I delete the custom properties and I recreate it, I have noticed that this item is not being recreated, and when I "transmit" the sheets I get an internal error
here is the code I use:
Private Sub DeleteCustomProperties(ByRef myItem As IAcSmPersist, Optional ByVal Lock As Boolean = True)
''Throw New NotImplementedException
Dim myDB As AcSmDatabase = myItem.GetDatabase
Try
Select Case myItem.GetTypeName
Case "AcSmSheetSet"
If True Then
Dim mySheetset As AcSmSheetSet = myItem
mySheetset.GetCustomPropertyBag.Clear()
mySheetset.GetCustomPropertyBag.InitNew(myItem)
Exit Select
Case "AcSmSheet"
If True Then
Dim mySheet As AcSmSheet = myItem
mySheet.GetCustomPropertyBag.Clear()
mySheet.GetCustomPropertyBag.InitNew(myItem)
Exit Select
End Select
Catch ex As Exception
End Try
End Sub
I then have routines that add back the custom properties that our office use (approx 140 ish custom properties)
This all works, but as statedt this "transmittalSetups" custom properties also gets deleted, It took a while to find this little sucker and am not too sure how to handle it.
Thanks if you have and help to offer.
Message 4 of 14
fenton.webb
To remove transmittal setups (resetting it), if you can find the property called "TransmittalSetups" and delete it, I think you'll be there (Make sure you do it before you blow away the Properties).
Lucikly, if no TransmittalSetups are found it automatically gets recreated.
I hope this helps.
Fenton Webb
AutoCAD Engineering
Message 5 of 14
Fenton,
Thanks for the information. I have not experianced this recreation of the "transmittalsetups", if not present. Do I need to delete the whole "custom property bag" and recreate it for it to be automaticaly recreated inside this contrainer.
My code (shown above) resets (clears) the "custom property bag" container, it does not delete it.
Is there a method to delete the custom property bag it, and recreate it? and more importantly if true, how?
Again thanks for any help you or others more proficient in this can offer.
Adam Kalajzich.
Message 6 of 14
Balaji_Ram
Hi Adam,
I have tried clearing the custom properties of the sheetset but it does not seem to be removing the transmittal setup.
I have attached the dropbox link to the recording that shows the steps that I am following. Can you see if there is anything different from what you are trying ?
https://www.dropbox.com/sh/40lbj5vv1nl8ri5/2Jb7I7SZcv
Here is the sample code that I am using to clear the custom properties
    <CommandMethod("ClearCP")> _
    Public Sub ClearCustomProps()
        Dim iterDb As IAcSmEnumDatabase
        Dim ItemDb As IAcSmPersist
        sheetSetMgr = New AcSmSheetSetMgr
        iterDb = sheetSetMgr.GetDatabaseEnumerator
        ItemDb = iterDb.Next
        sheetdb = ItemDb
        LockDatabase()
        Dim cBag1 As IAcSmCustomPropertyBag
        cBag1 = sheetdb.GetSheetSet().GetCustomPropertyBag
        cBag1.Clear()
        Dim Item1 As IAcSmPersist
        Dim iter1 As IAcSmEnumPersist
        iter1 = sheetdb.GetEnumerator
        Item1 = iter1.Next
        cBag1.InitNew(Item1)
        UnlockDatabase()
    End Sub
Balaji
Developer Technical Services
Autodesk Developer Network
Message 7 of 14
in reply to: Balaji_Ram
Balaji,
Thanks for taking the time to demonstrate and show example code. I will experiment with my code base to see if this solution also fits.
From what I can see, your assigning a veriable to the CPB, and processing that object directly, instead of the objects parent (if im explaining it properly???)
ie: my code needs to change to this:
    Try
        Case "AcSmSheetSet"
            If True Then
                Dim myCPB As IAcSmCustomPropertyBag '' new
                myCPB = mySheetset.GetCustomPropertyBag '' new
                myCPB.Clear() '' new
                '' mySheetset.GetCustomPropertyBag.Clear() '' old
                '' mySheetset.GetCustomPropertyBag.InitNew(myItem) '' old
                myCPB.InitNew(myItem) '' new
            Exit Select
        Case "AcSmSheet"
            If True Then
                '' mySheet.GetCustomPropertyBag.Clear() '' old
                ''mySheet.GetCustomPropertyBag.InitNew(myItem) '' old
            Exit Select
        End Select
    End Try
End Sub
Im a bit busy doing engineering at the moment, but I should be able to test and confirm this this week. If you belive this will not work, please let me know.
Again, thanks for your help.
Adam.
Message 8 of 14
Balaji_Ram
Hi Adam,
Not a problem.
Please feel free to test it when convenient.
Balaji
Message 9 of 14
Balaji,
I have attempted to incorporate your code example into my code (as shown above) but for some reason it is not working.
I have to iterate though all sheets, and clear the custom properties and recreate them (recreating the custom properties is being handled by another routine). I am passing the "myItem" object as an IAcSmPersist object (based on other code examples for iterating and analysing such objects), so the objects should work, but I cannot seem to work it out.
Your example works on the sheetset, but does not work on the sheets themselves, which shows that the CPB is being recreated, on the parent, but it is not processing the individual sheets.
Please if you can assist me I would really appreciate it.
Message 10 of 14
Balaji_Ram
Hi Adam,
Sorry, I still could not reproduce the problem.
Here is the sample code that I am using to clear the custom properties for a sheet and the dropbox link to the recording.
    <CommandMethod("ClearSheetCP")> _
    Public Sub ClearSheetCustomProps()
        Dim doc As Document
        doc = Application.DocumentManager.MdiActiveDocument
        Dim ed As Autodesk.AutoCAD.EditorInput.Editor
        ed = doc.Editor
        sheetdb = ItemDb
        LockDatabase()
        Dim sheetsetEnum As IAcSmEnumComponent
        sheetsetEnum = sheetdb.GetSheetSet().GetSheetEnumerator()
        Dim sheetsetItem As IAcSmComponent
        sheetsetItem = sheetsetEnum.Next()
        Dim iterator As IAcSmEnumPersist
        iterator = sheetdb.GetEnumerator()
        Dim item As IAcSmPersist
        item = iterator.Next()
        While item IsNot Nothing
            Dim type As String
            type = item.GetTypeName()
            Select Case type
                Case "AcSmSheet"
                    Dim sheet As IAcSmSheet = TryCast(item, IAcSmSheet)
                    cBag1 = sheet.GetCustomPropertyBag
                    cBag1.Clear()
                    Item1 = iter1.Next
                Case Else
                    ed.WriteMessage("vbCrLfType :" + type)
            End Select
        End While
        UnlockDatabase()
    End Sub
Can you please provide the steps and a buildable sample project to reproduce the issue ?
Please do not send any information that you consider confidential.
Balaji
Message 11 of 14
Balaji,
I have sent you a PM with the drop box link.
Message 12 of 14
Balaji_Ram
Hi Adam,
Can you please let me know the steps to reproduce the problem.
I can run the command and the custom properties are all added to the sheet.
But beyond that I have no idea how to get to the missing transmittal setup problem that you are having.
Maybe some step-by-step screenshots or a recording of the steps will help.
Balaji
Message 13 of 14
homer_anave
A good day to all of you.
I would like to continue this thread and seek for a solution, as I am also encountering an error within AutoCAD but it also crashes AutoCAD.
This is attained when I activate our program that edits the property values in a sheet or a sheet set.
Here is the procedure:
1.) Load a sheet set file that does not contain the "TransmittalSetups" custom property.
2.) Run the e-Transmit command by right-clicking the sheet set name at the tree view of the sheet set manager and selecting "e-Transmit".
3.) Cancel the dialog that will appear.
4.) Load the program that edits the property values in the sheet set/sheet. Make sure even one of the property values is changed.
5.) Try to run e-Transmit as 2.) again, and this will cause an error and eventually crash AutoCAD.
By the way, we are using AutoCAD 2012.
Hope we can get an answer.
Thank you!
Message 14 of 14
jeff
in reply to: homer_anave
Hi looks like you can change TransmittalSetups by just adding the corrects bytes to file or to make much life much easier just use a simple subsitution cipher to decode it to a xml file.
Here is part of the sheet set file that comes with autocad samples you will see transmittal setups at bottom.
I will post code for converting soon but pretty easy figure out mapping since you modify the sheet set file see results.
Here is a start
http://www.theswamp.org/index.php?topic=46497.0
<?xmlversion="1.0"encoding="UTF-8"?>
<AcSmDatabaseclsid="g2162C6B6-0CE4-40E8-912B-46F59DFDF826"ID="gA9DFEA28-A450-4076-8C0F-6ABA0418E5FF">
<AcSmProppropname="DbFingerPrint"vt="8">g89B8180B-4DB0-4C97-974E-01F9483859B8</AcSmProp>
<AcSmProppropname="DbVersion"vt="8">1.1</AcSmProp>
<AcSmProppropname="FileRevision"vt="3">36</AcSmProp>
<AcSmSheetSetclsid="gB20534F2-0978-418C-8D14-2E6928A077ED"ID="g50786B62-0394-4DC2-B91D-3790BAB7A345"propname="SheetSet"vt="13">
<AcSmFileReferenceclsid="g6BF87AE7-1BEC-4BDB-98BB-5B91F7772793"ID="gC9C96A82-979D-4EA0-B827-97B8D27C0B06"propname="AltPageSetups"vt="13">
<AcSmProppropname="Environ_FileName"vt="8">%ProgramFiles%\AutoCAD 2006\Sample\Sheet Sets\Architectural\IRD.dwt</AcSmProp>
<AcSmProppropname="FileName"vt="8">C:\Program Files\AutoCAD 2006\Sample\Sheet Sets\Architectural\IRD.dwt</AcSmProp>
<AcSmProppropname="Relative_FileName"vt="8">.\IRD.dwt</AcSmProp>
<AcSmProppropname="SpecialFolder_FileName"vt="8">$(CSIDL_PROGRAM_FILES)\AutoCAD 2006\Sample\Sheet Sets\Architectural\IRD.dwt</AcSmProp>
</AcSmFileReference>
<AcSmCalloutBlocksclsid="g203EAB46-483B-4E6B-A10B-15E9A4B210FF"ID="g3D8FB2D2-42BE-408B-9DC8-59C4B2DF4142"propname="CalloutBlocks"vt="13">
<AcSmAcDbBlockRecordReferenceclsid="g11782523-474B-4C83-9646-57C052847FBB"ID="g82BD5C32-9E78-4A1D-A4D4-8F5AE4FAC610">
<AcSmProppropname="AcDbHandle"vt="8">25C04</AcSmProp>
<AcSmProppropname="Name"vt="8">Callout Bubble</AcSmProp>
</AcSmAcDbBlockRecordReference>
<AcSmCustomPropertyValueclsid="g8D22A2A4-1777-4D78-84CC-69EF741FE954"ID="gE16F3C7B-AA0F-4BDB-B7DB-FD7655411FDC"propname="TransmittalSetups"vt="13">
<SSTransmittalSetups.16clsid="g087CF7BD-9343-4946-8BEE-44578710527E"ID="gCA88A6E5-F97C-41CC-8450-76CCA4B03351"propname="Value"vt="13">
<SSTransmittalSetup.16clsid="gFEBD61A0-4DCA-4CC1-A461-6801ED213209"ID="gD3E48FF3-5A43-49A5-BE47-F8CB680AB2F3">
<AcSmProppropname="IncludeDataLinkFile"vt="3">1</AcSmProp>
<AcSmProppropname="IncludeMaterialTextures"vt="3">1</AcSmProp>
<AcSmProppropname="IncludePhotometricWebFile"vt="3">1</AcSmProp>
<AcSmProppropname="IncludeSSFiles"vt="3">1</AcSmProp>
<AcSmProppropname="SetupName"vt="8">Standard</AcSmProp>
<AcSmProppropname="VisualFidelity"vt="3">1</AcSmProp>
</SSTransmittalSetup.16>
<SSTransmittalSetup.16clsid="gFEBD61A0-4DCA-4CC1-A461-6801ED213209"ID="g0B4A5B1A-F80D-4DB3-8FCE-FF3721CEB693">
<AcSmProppropname="IncludeUnloadedReferences"vt="3">1</AcSmProp>
<AcSmProppropname="SetupName"vt="8">ArchiveStandard</AcSmProp>
</SSTransmittalSetups.16>
</AcSmCustomPropertyValue>
</AcSmCustomPropertyBag>
You can also find your answers @ TheSwamp
”Boost
