.NET
Active Contributor
adamkalajzich
Message 11 of 14 (162 Views)
Re: Sheet set custom property field "TransmittalSetups"
01-24-2013 06:19 PM in reply to: Balaji_Ram
Balaji,
I have sent you a PM with the drop box link.
ADN Support Specialist
Balaji_Ram
Message 12 of 14 (155 Views)
01-24-2013 09:52 PM in reply to: adamkalajzich
Hi Adam,
Can you please let me know the steps to reproduce the problem.
I can run the command and the custom properties are all added to the sheet.
But beyond that I have no idea how to get to the missing transmittal setup problem that you are having.
Maybe some step-by-step screenshots or a recording of the steps will help.
Balaji
Developer Technical Services
Autodesk Developer Network
Active Member
hps_anave
Message 13 of 14 (89 Views)
01-13-2014 06:56 PM in reply to: adamkalajzich
A good day to all of you.
I would like to continue this thread and seek for a solution, as I am also encountering an error within AutoCAD but it also crashes AutoCAD.
This is attained when I activate our program that edits the property values in a sheet or a sheet set.
Here is the procedure:
1.) Load a sheet set file that does not contain the "TransmittalSetups" custom property.
2.) Run the e-Transmit command by right-clicking the sheet set name at the tree view of the sheet set manager and selecting "e-Transmit".
3.) Cancel the dialog that will appear.
4.) Load the program that edits the property values in the sheet set/sheet. Make sure even one of the property values is changed.
5.) Try to run e-Transmit as 2.) again, and this will cause an error and eventually crash AutoCAD.
By the way, we are using AutoCAD 2012.
Hope we can get an answer.
Thank you!
Valued Mentor
jeff
Message 14 of 14 (59 Views)
03-11-2014 10:51 PM in reply to: hps_anave
Hi looks like you can change TransmittalSetups by just adding the corrects bytes to file or to make much life much easier just use a simple subsitution cipher to decode it to a xml file.
Here is part of the sheet set file that comes with autocad samples you will see transmittal setups at bottom.
I will post code for converting soon but pretty easy figure out mapping since you modify the sheet set file see results.
Here is a start
http://www.theswamp.org/index.php?topic=46497.0
<?xmlversion="1.0"encoding="UTF-8"?>
<AcSmDatabaseclsid="g2162C6B6-0CE4-40E8-912B-46F59DFDF826"ID="gA9DFEA28-A450-4076-8C0F-6ABA0418E5FF">
<AcSmProppropname="DbFingerPrint"vt="8">g89B8180B-4DB0-4C97-974E-01F9483859B8</AcSmProp>
<AcSmProppropname="DbVersion"vt="8">1.1</AcSmProp>
<AcSmProppropname="FileRevision"vt="3">36</AcSmProp>
<AcSmSheetSetclsid="gB20534F2-0978-418C-8D14-2E6928A077ED"ID="g50786B62-0394-4DC2-B91D-3790BAB7A345"propname="SheetSet"vt="13">
<AcSmFileReferenceclsid="g6BF87AE7-1BEC-4BDB-98BB-5B91F7772793"ID="gC9C96A82-979D-4EA0-B827-97B8D27C0B06"propname="AltPageSetups"vt="13">
<AcSmProppropname="Environ_FileName"vt="8">%ProgramFiles%\AutoCAD 2006\Sample\Sheet Sets\Architectural\IRD.dwt</AcSmProp>
<AcSmProppropname="FileName"vt="8">C:\Program Files\AutoCAD 2006\Sample\Sheet Sets\Architectural\IRD.dwt</AcSmProp>
<AcSmProppropname="Relative_FileName"vt="8">.\IRD.dwt</AcSmProp>
<AcSmProppropname="SpecialFolder_FileName"vt="8">$(CSIDL_PROGRAM_FILES)\AutoCAD 2006\Sample\Sheet Sets\Architectural\IRD.dwt</AcSmProp>
</AcSmFileReference>
<AcSmCalloutBlocksclsid="g203EAB46-483B-4E6B-A10B-15E9A4B210FF"ID="g3D8FB2D2-42BE-408B-9DC8-59C4B2DF4142"propname="CalloutBlocks"vt="13">
<AcSmAcDbBlockRecordReferenceclsid="g11782523-474B-4C83-9646-57C052847FBB"ID="g82BD5C32-9E78-4A1D-A4D4-8F5AE4FAC610">
<AcSmProppropname="AcDbHandle"vt="8">25C04</AcSmProp>
<AcSmProppropname="Name"vt="8">Callout Bubble</AcSmProp>
</AcSmAcDbBlockRecordReference>
<AcSmCustomPropertyValueclsid="g8D22A2A4-1777-4D78-84CC-69EF741FE954"ID="gE16F3C7B-AA0F-4BDB-B7DB-FD7655411FDC"propname="TransmittalSetups"vt="13">
<SSTransmittalSetups.16clsid="g087CF7BD-9343-4946-8BEE-44578710527E"ID="gCA88A6E5-F97C-41CC-8450-76CCA4B03351"propname="Value"vt="13">
<SSTransmittalSetup.16clsid="gFEBD61A0-4DCA-4CC1-A461-6801ED213209"ID="gD3E48FF3-5A43-49A5-BE47-F8CB680AB2F3">
<AcSmProppropname="IncludeDataLinkFile"vt="3">1</AcSmProp>
<AcSmProppropname="IncludeMaterialTextures"vt="3">1</AcSmProp>
<AcSmProppropname="IncludePhotometricWebFile"vt="3">1</AcSmProp>
<AcSmProppropname="IncludeSSFiles"vt="3">1</AcSmProp>
<AcSmProppropname="SetupName"vt="8">Standard</AcSmProp>
<AcSmProppropname="VisualFidelity"vt="3">1</AcSmProp>
</SSTransmittalSetup.16>
<SSTransmittalSetup.16clsid="gFEBD61A0-4DCA-4CC1-A461-6801ED213209"ID="g0B4A5B1A-F80D-4DB3-8FCE-FF3721CEB693">
<AcSmProppropname="IncludeUnloadedReferences"vt="3">1</AcSmProp>
<AcSmProppropname="SetupName"vt="8">ArchiveStandard</AcSmProp>
</SSTransmittalSetups.16>
</AcSmCustomPropertyValue>
</AcSmCustomPropertyBag>
You can also find your answers @ TheSwamp
