.NET
Setting up VS 2005
3 REPLIES 3
267 Views, 3 Replies
Setting up VS 2005
I wanted to start converting code from VB6 to
VS2005.  Are there any configuration items/pointers to keep in mind?
We use mostly VB and LISP...
3 REPLIES 3
Anybody venture into 2005 yet?
mind?  We use mostly VB and
LISP...
Yes, but I don't have VB6 code to convert. VS 2005
(june CTP) works fine with AutoCAD.
Albert
LISP...
Here is a document I found awhile back. I hope it is of some value to you.
You are much better off converting the code manually, if you use M$ to upgrade the VB6 project, it brings in a ton of VB6 compatiblity objects (a kludge IMHO).
”Boost
