.NET
Setting Path value of Insert window.
2 REPLIES 2
RamanSBV
318 Views, 2 Replies
Using .Net code
How i can i set the value for Path field of "Insert" window.
Please advise.
Raman
2 REPLIES 2
Alfred.NESWADBA
in reply to: RamanSBV
mybe I don't understand the question, but the path-field (that I know in the _INSERT dialog) can't be set before you select a file! It does just report the path to the file you have selected. Without selection ... no path of a selection ;(
- alfred -
Alfred NESWADBA
Ingenieur Studio HOLLAUS ... www.hollaus.at ... blog.hollaus.at ... CDay 2024
(not an Autodesk consultant)
Do you mean the insert value as in the location of the dialog on the screen?
If so:
        '' dialog
        Dim ss As New DiaglogName
        Application.ShowModelessDialog(ss)
        ' Location of window
        Dim x As Integer = ((PrimaryScreen.WorkingArea.Width) / 2) - (ss.Width / 2)
        Dim y As Integer = ((PrimaryScreen.WorkingArea.Height) / 2) - ((ss.Height / 100) * 65)
        ss.Location = New System.Drawing.Point(x, y)
Sorry if I missed the point
”Boost
