.NET
Valued Contributor
RamanSBV
Message 1 of 3 (143 Views)
Setting Path value of Insert window.
143 Views, 2 Replies
03-01-2012 01:42 AM
Using .Net code
How i can i set the value for Path field of "Insert" window.
Please advise.
Raman
Alfred.NESWADBA
Message 2 of 3 (119 Views)
Re: Setting Path value of Insert window.
03-03-2012 06:45 AM in reply to: RamanSBV
mybe I don't understand the question, but the path-field (that I know in the _INSERT dialog) can't be set before you select a file! It does just report the path to the file you have selected. Without selection ... no path of a selection ;(
- alfred -
Alfred NESWADBA
Active Contributor
DesignProQuig
Message 3 of 3 (118 Views)
03-03-2012 07:09 AM in reply to: RamanSBV
Do you mean the insert value as in the location of the dialog on the screen?
If so:
        '' dialog
        Dim ss As New DiaglogName
        Application.ShowModelessDialog(ss)
        ' Location of window
        Dim x As Integer = ((PrimaryScreen.WorkingArea.Width) / 2) - (ss.Width / 2)
        Dim y As Integer = ((PrimaryScreen.WorkingArea.Height) / 2) - ((ss.Height / 100) * 65)
        ss.Location = New System.Drawing.Point(x, y)
Sorry if I missed the point
http://www.designprosoftware.co.uk/
