.NET
Valued Contributor
0 Kudos
Post 1 of 14
Setting focus back to AutoCAD
976 Views, 13 Replies
08-14-2013 01:57 PM
I have written a VB.NET function that exports data from AutoCAD and imports it into a new Excel worksheet.
The code runs as I want it to, however, when all the data has been added to Excel, I want the control to go back to AutoCAD to display a msgbox that the routine has finished.
The msgbox comes up, but it does not put focus back to AutoCAD. If the excel window is ontop of AutoCAD, the user has no idea when the routine is finished.
Any ideas how to do this would be much appreciated?
cj
Well I tried something different and got an appropriate solution. I added the following before my MsgBox.
Excel now minimizes and then Autocad is the main visible application showing my message to the user.
Not sure why I didn't find this earlier but sometime a step away brings new ideas when you return.
thanks to everyone who provided responses.
cj
myExcel.WindowState = Microsoft.Office.Interop.Excel.XlWindowState.xlMinimized
37 Kudos
Post 2 of 14
Re: Setting focus back to AutoCAD
08-14-2013 02:15 PM in reply to: cjacobi
 You could try this
Autodesk.AutoCAD.Internal.Utils.SetFocusToDwgView()
(defun botsbuildbots() (botsbuildbots))
Valued Contributor
0 Kudos
Post 3 of 14
08-15-2013 10:38 AM in reply to: arcticad
Thanks for the response.
I added that into my code just before the MsgBox. Still no go.
In the code I'm adding rows into Excel so Excel is the active window. But when the routine is done, it still sits with Excel as the active window....I figured the MsgBox should make Autocad the active window.....even with your added suggestion, it does not bring it infront of Excel.
504 Kudos
Post 4 of 14
08-15-2013 10:58 AM in reply to: cjacobi
Won't the Excel application have a means to minimize the application window, thus restoring the AutoCAD application to the foreground?
Adopt. Adapt. Overcome. Or be overcome.
A good question will be halfway to a good answer.
37 Kudos
Post 5 of 14
08-15-2013 11:29 AM in reply to: dgorsman
There are some ideas posted here
http://stackoverflow.com/questions/2315561/correct-way-in-net-to-switch-the-focus-to-another-applica...
if you set the excel.application visible = false does this do anything helpful?
Valued Contributor
0 Kudos
Post 6 of 14
08-15-2013 11:37 AM in reply to: arcticad
thanks...I will check that link out.
Your sugestion of
myExcel.Application.Visible = False
Closes Excel right down....doesn't even ask to save the file.
Valued Contributor
4 Kudos
Post 7 of 14
08-15-2013 11:42 AM in reply to: arcticad
I have done extensive work with Excel and have some good code for running it.  First detect if it is running, then...
   Private MyXL As Microsoft.Office.Interop.Excel.Application 'Excel.Application
   Private objWorkbook As Microsoft.Office.Interop.Excel._Workbook 'Excel.Workbook
   Private objWorksheet As Microsoft.Office.Interop.Excel._Worksheet 'Excel.Worksheet
Function
... ... ... ... in closing the function: If PrintFooter = True Then objWorksheet.PageSetup.LeftFooter = System.DateTime.Today.Date objWorksheet.PageSetup.RightFooter = System.DateTime.Now.TimeOfDay.ToString ' & ":" & System.DateTime.Now.Minute.ToString ' objWorksheet.PageSetup.PrintTitleRows End If objWorksheet.PrintPreview() On Error Resume Next MyXL.Visible = True MyXL.DisplayAlerts = True If ExcelWasNotRunning = True Then objWorksheet = Nothing MyXL.Application.Quit() End If 'Free up memory, otherwise there will be a memory leak. objWorksheet = Nothing objWorkbook = Nothing MyXL = Nothing 'Screen.MousePointer = vbDefault Exit Sub
 closing out of excel seems to be causing a problem.
Learning as I go
Valued Contributor
4 Kudos
Post 8 of 14
08-15-2013 11:51 AM in reply to: jaboone
I will also ask if you are using perimeter lines for border lines in your sheet, especially double lines?
Learning as I go
37 Kudos
Post 9 of 14
08-15-2013 11:53 AM in reply to: jaboone
Excel has a known bug about closing down.
The attached code will force Excel to close.
The visible.false will not close excel, it is still running. You just can't see the interface, I was hoping it would switch back to AutoCAD when you tried it
Valued Contributor
4 Kudos
Post 10 of 14
08-15-2013 12:50 PM in reply to: arcticad
Yes I have had some torubles closing excel clopletely.  Thanks for the extra code to close it down.
Learning as I go
