.NET
Valued Contributor
cjacobi
Message 1 of 14 (752 Views)
Setting focus back to AutoCAD
752 Views, 13 Replies
08-14-2013 01:57 PM
I have written a VB.NET function that exports data from AutoCAD and imports it into a new Excel worksheet.
The code runs as I want it to, however, when all the data has been added to Excel, I want the control to go back to AutoCAD to display a msgbox that the routine has finished.
The msgbox comes up, but it does not put focus back to AutoCAD. If the excel window is ontop of AutoCAD, the user has no idea when the routine is finished.
Any ideas how to do this would be much appreciated?
cj
arcticad
Message 2 of 14 (750 Views)
Re: Setting focus back to AutoCAD
08-14-2013 02:15 PM in reply to: cjacobi
 You could try this
Autodesk.AutoCAD.Internal.Utils.SetFocusToDwgView()
(defun botsbuildbots() (botsbuildbots))
Valued Contributor
cjacobi
Message 3 of 14 (717 Views)
08-15-2013 10:38 AM in reply to: arcticad
Thanks for the response.
I added that into my code just before the MsgBox. Still no go.
In the code I'm adding rows into Excel so Excel is the active window. But when the routine is done, it still sits with Excel as the active window....I figured the MsgBox should make Autocad the active window.....even with your added suggestion, it does not bring it infront of Excel.
dgorsman
Message 4 of 14 (708 Views)
08-15-2013 10:58 AM in reply to: cjacobi
Won't the Excel application have a means to minimize the application window, thus restoring the AutoCAD application to the foreground?
Adopt. Adapt. Overcome. Or be overcome.
A good question will be halfway to a good answer.
arcticad
Message 5 of 14 (705 Views)
08-15-2013 11:29 AM in reply to: dgorsman
There are some ideas posted here
http://stackoverflow.com/questions/2315561/correct-way-in-net-to-switch-the-focus-to-another-applica...
if you set the excel.application visible = false does this do anything helpful?
Valued Contributor
cjacobi
Message 6 of 14 (700 Views)
08-15-2013 11:37 AM in reply to: arcticad
thanks...I will check that link out.
Your sugestion of
myExcel.Application.Visible = False
Closes Excel right down....doesn't even ask to save the file.
Valued Contributor
jaboone
Message 7 of 14 (698 Views)
08-15-2013 11:42 AM in reply to: arcticad
I have done extensive work with Excel and have some good code for running it.  First detect if it is running, then...
   Private MyXL As Microsoft.Office.Interop.Excel.Application 'Excel.Application
   Private objWorkbook As Microsoft.Office.Interop.Excel._Workbook 'Excel.Workbook
   Private objWorksheet As Microsoft.Office.Interop.Excel._Worksheet 'Excel.Worksheet
Function
... ... ... ... in closing the function: If PrintFooter = True Then objWorksheet.PageSetup.LeftFooter = System.DateTime.Today.Date objWorksheet.PageSetup.RightFooter = System.DateTime.Now.TimeOfDay.ToString ' & ":" & System.DateTime.Now.Minute.ToString ' objWorksheet.PageSetup.PrintTitleRows End If objWorksheet.PrintPreview() On Error Resume Next MyXL.Visible = True MyXL.DisplayAlerts = True If ExcelWasNotRunning = True Then objWorksheet = Nothing MyXL.Application.Quit() End If 'Free up memory, otherwise there will be a memory leak. objWorksheet = Nothing objWorkbook = Nothing MyXL = Nothing 'Screen.MousePointer = vbDefault Exit Sub
 closing out of excel seems to be causing a problem.
Learning as I go
Valued Contributor
jaboone
Message 8 of 14 (693 Views)
08-15-2013 11:51 AM in reply to: jaboone
I will also ask if you are using perimeter lines for border lines in your sheet, especially double lines?
Learning as I go
arcticad
Message 9 of 14 (688 Views)
08-15-2013 11:53 AM in reply to: jaboone
Excel has a known bug about closing down.
The attached code will force Excel to close.
The visible.false will not close excel, it is still running. You just can't see the interface, I was hoping it would switch back to AutoCAD when you tried it
Valued Contributor
jaboone
Message 10 of 14 (674 Views)
08-15-2013 12:50 PM in reply to: arcticad
Yes I have had some torubles closing excel clopletely.  Thanks for the extra code to close it down.
Learning as I go
