I'm using VB.Net in Visual Studio version 2010 with AutoCad 2010. I haven't had a problem with this before, but now it seems that the program ignores break points that I set in the code when I'm trying to debug. I just want to pause the code and add a "watch" to a variable.
Anyone have a step by step way to do this as the msn method isn't working.
Mark
Solved by adadnet. Go to Solution.
So this project was already working in the debugger?
Additional questions:
- alfred -
if you have VS2010 EXpress you need to add this manualy in the 'file NameOfYouProject'.vbproj :
<StartAction>Program</StartAction>
<StartProgram>c:\Program Files\AutoCAD 2010\acad.exe</StartProgram>
after the line :
<PropertyGroup Condition=" '$(Configuration)|$(Platform)' == 'Debug|AnyCPU' ">
and after :
<PropertyGroup Condition=" '$(Configuration)|$(Platform)' == 'Release|AnyCPU' ">
the site http://through-the-interface.typepad.com/t...... is for a registered VS2010. so Solution 1 and 3 you cant do this.
For Solution 2 it a file in your 'C:\Program Files\AutoCAD 2010' if you have this path for autocad.
Hello Alfred,
My project is a .dll.
I believe the only references I added were AcDbMgd.dll and AcMgd.dll from ObjectARX 2010, inc-x64.
As for the framework, where do I find that information?
Mark
Hello Felix,
Thank you for the link, but I'm a newbie at VB.Net and I'm not sure my program is what they are talking about. I don't see a "solution" in the Solution Explorer (see pics).
Mark
hi mark
sorry that was a bit short - i remember that what i did at the time was what kean refers to as solution 2 and that is allocate the acad configuration file, which doesn't contain much more than kean shows, and change the version to 4.0, in my case. i think this version then needs to conform to the project's target framework: project -> project properties to open the properties tab, highlight compile, scroll down and choose advanced compile options -> set your target framework at the bottom. (i hope that will see you through)
felix
Hi Felix,
I did what you did. I copied the text from Keans site (step 2) and put it in my acad.exe.config file. That did the trick.
Mark
