.NET
Setting Attachment path default for XRef, PDF, Image, & DWF
1 REPLY 1
michael.robertson
800 Views, 1 Reply
Looking for registry keys to control the default attachment type (Full, Relative, & No Path) for XRef, Image, PDF, & DWF in the attachment dialog. (I'm using C3D but this applies to plain ACad also).
For XRef the key is:
HKEY_CURRENT_USER\Software\Autodesk\AutoCAD\R18.2\ACAD-A000:409\Profiles\MyWorkSpace\Dialogs\XattachDialog
The value is "PathType" DWORD = 1 for relativepath
For Image the key is:
HKEY_CURRENT_USER\Software\Autodesk\AutoCAD\R18.2\ACAD-A000:409\ISM
The value is "ImagePathType" DWORD = 1 for relative path (NOTE: this value didn't exist, once I created it, C3D used the key for both storing the value when closing C3D the reading the value when presenting the attach dialog).
Looking for keys that control PDF & DWF attachments.
Mike
Mike Robertson
FL. Dept. of Transportation
CADD Applications Developer
1 REPLY 1
What would the FULL Registry Path be for AutoCAD Mechanical 2014 under Product Design Suite 2014 to update XrefPath to Relative....?
Cheers
DP
”Boost
