.NET
SetPlotorigin not working
6 REPLIES 6
GeeHaa
855 Views, 6 Replies
acPlSetVdr.SetPlotRotation(acPlSet, orient) Dim xyoff As Point2d = New Point2d(Convert.ToDouble(Xoff), Convert.ToDouble(Yoff)) If Xoff = "0.0" And Yoff = "0.0" Then '' Center the plot acPlSetVdr.SetPlotCentered(acPlSet, True) Else acPlSetVdr.SetPlotCentered(acPlSet, False) acPlSetVdr.SetPlotOrigin(acPlSet, xyoff) 'MsgBox(acPlSet.PlotOrigin.ToString) End If
Can anyone tell me why the plot origin does not move. It is staying centered even though I set it to 0,3
I'm using a transaction. The msgBox come up with (0,3). Plot rotation works.
Thanks in Advance
6 REPLIES 6
in reply to: GeeHaa
Try doing the
statement without an IF statement. See what that does.
Good luck!
GeeHaa
in reply to: GeeHaa
When I step through the code it executes the statements following the else condition. But I tried moving it out- Still does not change the origin. I also checked for a rouge setplotcentered statement. But find did not find anything with the word centered in it other than the if statement.
in reply to: GeeHaa
my guess is
1. copy the new, validated settings back to the layout;
2. check any collision of settings that directly affect the plot origin, in particular plot area and plot type.
felix
GeeHaa
in reply to: GeeHaa
The only thing I am setting is the plot type ->Autodesk.AutoCAD.DatabaseServices.PlotType.Extents
My thinking is if changing the origin pushes part of the plot off the page it should automatically just clip it.
in reply to: GeeHaa
well, that could be it, precisley: plottype.extents is said to print everything within the boundaries of the current space. in turn this could determine the plotorigin. if that holds true, you might have just answered it
GeeHaa
in reply to: GeeHaa
I figured it out. I just remembered the offset is in millimeters so with (0,3) I couldn't tell it moved. I multiplied by 25.4 It works.
Thanks for all your help.
”Boost
