.NET
.NET
Valued Contributor
4 Kudos
Post 1 of 2
set undo-functionality off for current transaction
134 Views, 1 Replies
02-17-2014 12:45 AM
how can i turn off the undo-functionality in the current / next started transaction?
regards Mario
Valued Contributor
4 Kudos
Post 2 of 2
Found a Solution, but without transaction
02-18-2014 11:30 AM in reply to: mario.rosenbohm
i have found a working solution. Based on this AutoCAD Devblog.
For the UndoOnOff-Class i using a Singleton-pattern, than can i call only one "Undo-SetOff()".
All code-comments in german, .. i am from .... ;-)
Using Undo-Off-On Class:
clUndoOnOff.Instance.SetOff();
... Start Transaction
... Work
... Commit Transaction
clUndoOnOff.Instance.SetOn();
Code (Singleton-Pattern):
using System;
using System.Collections.Generic;
using System.Linq;
using System.Text;
using System.Runtime.Serialization;
namespace KPlusS.KaliGmbH.CSharpTools.Pattern
    /// <summary>Basisklasse für ThreadSafe Sigleton.
    /// Bei den Ableitungen IMMER den Konstruktor auf private setzten !!"</summary>
    /// <typeparam name="T">Type(KlassenName der Klasse die Singleton werden soll)</typeparam>
    public abstract class SingletonBase<T>
      where T : SingletonBase<T>
        /// <summary>Die Instance</summary>
        private static volatile T instance = null;
        /// <summary>Thrad-Safe Lock-Object</summary>
        private static object syncRoot = new object();
        /// <summary>Getter der ThreadSafe-Instance der Sigleton</summary>
        public static T Instance
            get
                if (instance == null)
                    lock (syncRoot)
                            object obj = FormatterServices.GetUninitializedObject(typeof(T));
                            if (obj != null)
                                instance = obj as T;
                                instance.Init();
                else
                    instance.Refresh();
                return instance;
        /// <summary>Initialisierung der abgeleiteten Klasse</summary>
        protected virtual void Init()
        /// <summary>Aktualisierung der abgeleiteten Klasse</summary>
        protected virtual void Refresh()
Code (Class-UndoOnOff):
!!! The Commands is only for German AutoCAD (tested on 2011) !!!
On German Autocad work the english command "_undo" but not the english parameter "_control","_all" and other. :smileyfrustrated:
The command-text after "// english" .. should work at english AutoCAD.
using System;
using System.Linq;
using System.Text;
using KPlusS.KaliGmbH.CSharpTools.Pattern;
using Autodesk.AutoCAD.ApplicationServices;
using Autodesk.AutoCAD.DatabaseServices;
namespace KPlusS.KaliGmbH.AutoCAD.V2011.Dbs
    /// <summary>Undo ein und Ausschalten.
    /// Bitte mit Beadcht verwenden !!</summary>
    public class clUndoOnOff : SingletonBase<clUndoOnOff>
        #region Eigenschaften
        /// <summary>Wurde bereits ausgeschaltet?</summary>
        private Boolean haveSetOff;
        /// <summary>Command UNDO Auto ein</summary>
        private const String cmdAutoOn = "_undo g "; // english "_undo _all "
        /// <summary>Command UNDO Auto aus</summary>
        private const String cmdAutoOff = "_undo s n "; // english "_undo _Control _None "
        /// <summary>Command UNDO OnlyOneCommand ein</summary>
        private const String cmdOnlyOneCommandOn = "_undo e "; // english "_undo _one "
        /// <summary>Command UNDO OnlyOneCommand aus</summary>
        private const String cmdOnlyOneCommandOff = "_undo s n "; // Identisch mit cmdAutoOff!! english "_undo _Control _None "
        /// <summary>Command UNDO Layer ein</summary>
        private const String cmdLayerOn = "_undo l j "; // english "_undo _Layer _Yes"
        /// <summary>Command UNDO Layer aus</summary>
        private const String cmdLayerOff = "_undo l n "; // english "_undo _Layer _No"
        /// <summary>Command UNDO ZoomPan ein</summary>
        private const String cmdZoomPanOn = "_undo k j "; // english "_undo _C _Yes"
        /// <summary>Command UNDO ZoomPan aus</summary>
        private const String cmdZoomPanOff = "_undo k n "; // english "_undo _C _No"
        #endregion Eigenschaften
        #region Properties
        /// <summary>Undo ist ein?</summary>
        public Boolean UndoIsOn { get; private set; }
        /// <summary>Undo-EinKommando ist ein? ?</summary>
        public Boolean UndoIsOneCmd { get; private set; }
        /// <summary>Undo-Auto ist ein ?</summary>
        public Boolean UndoIsAuto { get; private set; }
        /// <summary>Undo-Group ist ein ?</summary>
        public Boolean UndoIsGroup { get; private set; }
        /// <summary>Undo-Zoom/Pan ist ein?</summary>
        public Boolean UndoIsZoomPan { get; private set; }
        /// <summary>Undo-Layer ist ein?</summary>
        public Boolean UndoIsLayer { get; private set; }
        /// <summary>SystemVariable Undo for ausschalten</summary>
        public Int16 UndoValue { get; private set; }
        #endregion Properties
        #region Konstruktoren
        /// <summary>Konstruktor = TOT</summary>
        private clUndoOnOff() { }
        #endregion Konstruktoren
        #region Methoden
        /// <summary></summary>
        protected override void Init()
            base.Init();
            haveSetOff = false;
        /// <summary>Testet die Systemvariable UNDO</summary>
        private void parseCurrentUndo()
            this.UndoValue = (Int16)Application.GetSystemVariable("UNDOCTL");
            this.UndoIsOn = (UndoValue & 1) == 1;
            this.UndoIsOneCmd = (UndoValue & 2) == 2;
            this.UndoIsAuto = (UndoValue & 4) == 4;
            this.UndoIsGroup = (UndoValue & 8) == 8;
            this.UndoIsZoomPan = (UndoValue & 16) == 16;
            this.UndoIsLayer = (UndoValue & 32) == 32;
        /// <summary>Undo ausschalten</summary>
        public void SetOff()
            if (haveSetOff) return;
            parseCurrentUndo();
            if (!UndoIsOn) return;
            // zu erst immer Auto und OnlyOneCommand aus
            String commandString = "";
            if (this.UndoIsAuto || this.UndoIsOneCmd) commandString += cmdAutoOff;
            if (this.UndoIsLayer) commandString += cmdLayerOff;
            if (this.UndoIsZoomPan) commandString += cmdZoomPanOff;
            Application.DocumentManager.MdiActiveDocument.SendStringToExecute(commandString, false, false, false);
            haveSetOff = true;
        /// <summary>Reaktiviert UNDOCTR auf den Stand den es vor dem SetOff hatte</summary>
        public void SetOn()
            if (haveSetOff)
                if (this.UndoValue > 0)
                    if (this.UndoIsZoomPan) commandString += cmdZoomPanOn;
                    if (this.UndoIsLayer) commandString += cmdLayerOn;
                    if (this.UndoIsAuto)
                        commandString += cmdAutoOn;
                    else
                        if (this.UndoIsOneCmd) commandString += cmdOnlyOneCommandOn;
                haveSetOff = false;
        #endregion Methoden
regards Mario
