.NET
Set screen center to my point
5 REPLIES 5
1580 Views, 5 Replies
At this time I tried to set screen center. I have some object and I want to set screen position to this object.
What I did:
 AcadApplication app = (AcadApplication)Autodesk.AutoCAD.ApplicationServices.Application.AcadApplication;
 using (Transaction tr = doc.Database.TransactionManager.StartTransaction())
      Entity en = (Entity)tr.GetObject(objectId, OpenMode.ForRead); // get my obj by Id
      Extents3d ext = en.GeometricExtents;
       Point3d p_center = new Point3d( // get center
                        (ext.MinPoint.X + ext.MaxPoint.X) / 2,
                        (ext.MinPoint.Y + ext.MaxPoint.Y) / 2,
                        (ext.MinPoint.Z + ext.MaxPoint.Z) / 2
     // set center point of current view
       ed.UpdateTiledViewportsInDatabase();
      ViewportTableRecord viewportTableRec = tr.GetObject(ed.ActiveViewportId, OpenMode.ForWrite) as ViewportTableRecord;
      viewportTableRec.CenterPoint = new Point2d(p_center.X, p_center.Y);
       ed.UpdateTiledViewportsFromDatabase();
   // Ok!
       tr.Commit();
  // set object as selected - it works
  doc.Editor.SetImpliedSelection(new ObjectId[] { objectId });
I see that SetImpliedSelection works fine (as I see current object) but screen center  is moved to unknown point.
How I can set screen center to my point?
Pavel.
5 REPLIES 5
Hallex
Something like this will do your work
      Matrix3d ucs = ed.CurrentUserCoordinateSystem;
       ).TransformBy(ucs);
~'J'~
_____________________________________
C6309D9E0751D165D0934D0621DFF27919
in reply to: Hallex
No changes 😞
I had created new schema and this code works, but still doesn't work in old, stored file.
It's very strange.
It seems in old file I have very specific view but I have no idea what it is.
Pavel.
_gile
You need to transform the Extents3d from World Coordinates System to the viewport Display Coordinates System before calculating the center point.
        private void SetViewCenterToObject(ObjectId id)
            Document doc = Application.DocumentManager.MdiActiveDocument;
            Editor ed = doc.Editor;
            using (Transaction tr = doc.TransactionManager.StartTransaction())
            using (ViewTableRecord view = ed.GetCurrentView())
                Matrix3d DCS2WCS =
                    Matrix3d.Rotation(-view.ViewTwist, view.ViewDirection, view.Target) *
                    Matrix3d.Displacement(view.Target - Point3d.Origin) *
                    Matrix3d.PlaneToWorld(view.ViewDirection);
                Entity ent = (Entity)tr.GetObject(id, OpenMode.ForRead);
                Extents3d ext = ent.GeometricExtents;
                ext.TransformBy(DCS2WCS.Inverse());
                view.CenterPoint = new Point2d(
(ext.MaxPoint.X + ext.MinPoint.X) / 2.0,
(ext.MaxPoint.Y + ext.MinPoint.Y) / 2.0); ed.SetCurrentView(view); tr.Commit(); } }
Gilles Chanteau
GileCAD
GitHub
in reply to: _gile
Wow! It works! Thanks, gile!
Pavel.
”Boost
