.NET
Set page setup current
3 REPLIES 3
MarkSanchezSPEC
1272 Views, 3 Replies
I have existing .NET code that adds page setups to drawings.  I now wanted to set the newly added page setup as "current" within the drawing.
The "manual" way to do what I am asking is by clicking the "Set Current" button from within the Page Setup Manager dialog.  How would I do this programmatically?
TIA
3 REPLIES 3
hyperpics
in reply to: MarkSanchezSPEC
Here is something similar to what I have done in the past.
Imports Autodesk.AutoCAD.Runtime
Imports Autodesk.AutoCAD.ApplicationServices
Imports Autodesk.AutoCAD.DatabaseServices
Imports Autodesk.AutoCAD.PlottingServices
' Assigns a page setup to a layout
<CommandMethod("AssignPageSetupToLayout")> _
Public Shared Sub AssignPageSetupToLayout()
    ' Get the current document and database, and start a transaction
    Dim acDoc As Document = Application.DocumentManager.MdiActiveDocument
    Dim acCurDb As Database = acDoc.Database
    Using acTrans As Transaction = acCurDb.TransactionManager.StartTransaction()
        ' Reference the Layout Manager
        Dim acLayoutMgr As LayoutManager = LayoutManager.Current
        ' Get the current layout and output its name in the Command Line window
        Dim acLayout As Layout = _
            acTrans.GetObject(acLayoutMgr.GetLayoutId(acLayoutMgr.CurrentLayout), _
                              OpenMode.ForRead)
        Dim acPlSet As DBDictionary = _
            acTrans.GetObject(acCurDb.PlotSettingsDictionaryId, OpenMode.ForRead)
        ' Check to see if the page setup exists
        If acPlSet.Contains("MyPageSetup") = True Then
            Dim plSet As PlotSettings = _
                acPlSet.GetAt("MyPageSetup").GetObject(OpenMode.ForRead)
            ' Update the layout
            acLayout.UpgradeOpen()
            acLayout.CopyFrom(plSet)
            ' Save the new objects to the database
            acTrans.Commit()
        Else
            ' Ignore the changes made
            acTrans.Abort()
        End If
    End Using
    ' Update the display
    acDoc.Editor.Regen()
End Sub
Works great!
I only had to add another using statement like this to lock the document:
Using dl as DocumentLock = dwg.LockDocument
End Using
 I think this is becuase I run in batch mode using:
    <CommandMethod("MYCOMMAND", CommandFlags.Session)>
Thanks a lot!
hyperpics
Glad it helped and you were able to adapt it to your particular situation.
”Boost
