.NET
Valued Contributor
andred
Message 1 of 10 (593 Views)
Set MDIACTIVEDOCUMENT not working
593 Views, 9 Replies
08-22-2013 02:05 PM
I have difficulties to set MDIActiveDocument. I read many post  but any is working. I create a sample program. That program open a drawing try to set it current and set a layout current. The drawing open but the MDIACTIVEDOCUMENT is always the drawing I run the program. I'm working with VS2010 and AutoCAD 2012.
Here's my class:
Imports Autodesk.AutoCAD.Runtime
Imports Autodesk.AutoCAD.ApplicationServices
Imports Autodesk.AutoCAD.DatabaseServices
Imports Autodesk.AutoCAD.EditorInput
Imports System.Windows.Forms
Imports System.IO
Public Class TestDocSwitch
    <CommandMethod("TestDocSwitch", CommandFlags.Session)> _
    Public Sub TestDocSwitch()
        Dim DWGNameToOpen As String = "D:\LOGESDES\3177\H90930\3177-90930-001-01-E-LR-1.DWG"
        Dim LayoutName As String = "Model"
        OpenDrawing(DWGNameToOpen, LayoutName)
    End Sub
    Public Sub OpenDrawing(DrawingName As String, Optional LayoutName As String = "")
        Dim acDocMgr As DocumentCollection = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager
        Dim acDoc As Autodesk.AutoCAD.ApplicationServices.Document = Nothing
        If (File.Exists(DrawingName)) Then
            acDoc = acDocMgr.Open(DrawingName, False)
        Else
            acDocMgr.MdiActiveDocument.Editor.WriteMessage("File " & DrawingName & " does not exist.")
        End If
        acDocMgr.MdiActiveDocument = acDoc
        If LayoutName <> "" Then
            SetCurrentLayoutTab(LayoutName)
        End If
    End Sub
    Public Sub SetCurrentLayoutTab(ByVal LayoutName As String)
        Dim acDoc As Document = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument
        MessageBox.Show(acDoc.Name)
        Dim acCurDb As Database = acDoc.Database
        Using doclock As DocumentLock = acDoc.LockDocument
            Using acTrans As Transaction = acCurDb.TransactionManager.StartTransaction()
                Try
                    Dim acLayoutMgr As LayoutManager
                    acLayoutMgr = LayoutManager.Current
                    acLayoutMgr.CurrentLayout = LayoutName
                    acTrans.Commit()
                Catch ex As Autodesk.AutoCAD.Runtime.Exception
                    Autodesk.AutoCAD.ApplicationServices.Application.ShowAlertDialog(ex.Message & vbCr & ex.StackTrace)
                    acTrans.Abort()
                End Try
            End Using
        End Using
    End Sub
End Class
In my complete program I need to obtain information about the current layout but it doesn't work because the active drawing is not the drawing I open.
Need help!
André
I confirm, set NEXTFIBERWORLD to 1 (default value) solve my problem in my main application.
André
mleslie00
Message 2 of 10 (589 Views)
Re: Set MDIACTIVEDOCUMENT not working
08-22-2013 02:12 PM in reply to: andred
My goodness! We are beating our heads on the same wall simultaneously! (Posted one minute apart)
http://forums.autodesk.com/t5/NET/Cannot-set-MdiActiveDocument/td-p/4377495
Valued Contributor
andred
Message 3 of 10 (576 Views)
08-22-2013 02:36 PM in reply to: andred
Thank you,
I read your post and it is not a problem only with 2013.
André
Hallex
Message 4 of 10 (546 Views)
08-23-2013 12:09 AM in reply to: andred
Tested yor code in 2014
Solution (on my end):
to avoid this error
//Error 1 ... 'TestDocSwitch': member names cannot be the same as their enclosing type //
Rename
Public Sub TestDocSwitch  on
Public Sub TestDocSwitchCommand
Also I've added refrerence to accoremgd.dll (copy local=false)
Let us know if this work on your release
Valued Contributor
andred
Message 5 of 10 (535 Views)
08-23-2013 05:07 AM in reply to: andred
Thank you for your reply Hallex,
It is not necessary to rename the command. The name can be the same (I use it all the time). The command is running, the only problem is Mdiactivedocument is not change. You can notice the MessageBox in the SetCurrentLayoutTab sub, it display the name of the first drawing, not the last drawing open.
Also the reference to accoremgd.dll is required only from 2013 release, not 2012.
André
Hallex
Message 6 of 10 (530 Views)
08-23-2013 05:40 AM in reply to: andred
Then take a look at your code
In the code snip the class and sub have identical name
TestDocSwitch, try rename frist or second one no matters
Valued Contributor
andred
Message 7 of 10 (525 Views)
08-23-2013 06:00 AM in reply to: andred
Thank you Hallex,
It doesn't change anything but I found my problem. When you debug with VS2010 and AutoCAD 2012 sometimes you have to set NEXTFIBERWORLD variable to 0. I don't know why exactly but it works. Usually I debug my app with this variable set to 0. I changed it to 1 (normal mode) and you have to restart AutoCAD to apply the changes. Voilà! my messagebox show the last open document name (not the first one). I will try it in my main application to be sure it is working well.
Maybe with AutoCAD 2013/2014 you don't have to set this variable. It was not necessary when I develop application for AutoCAD 2010 (VS2008).
Best regards,
André
Valued Contributor
andred
Message 8 of 10 (521 Views)
08-23-2013 06:11 AM in reply to: andred
André
Hallex
Message 9 of 10 (501 Views)
08-23-2013 12:03 PM in reply to: andred
Or without nextfiberword, try this code, tested from A2010 to 2014
it works everywhere:
        Public is_template As Boolean = True
        <CommandMethod("ts", CommandFlags.Session)> _
        Public Sub testNewDocOpen()
            Dim docs As DocumentCollection = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager
            Dim doc As Document = docs.MdiActiveDocument
            Dim ed As Editor = Nothing
            ''System.Windows.Forms.MessageBox.Show(Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument.Name)
            ' possible using examples:
            ' is_template = true;
            ' OpenDocCallback("acad.dwt");// <-- or acadiso.dwt
            ' Or
            is_template = False
            OpenDocCallback("C:\Test\WorkingDrawing.dwg") ' <-- your file name here
            docs.MdiActiveDocument = docs.MdiActiveDocument
            Dim newdoc As Document = docs.MdiActiveDocument
            ed = newdoc.Editor
            Using doclock As DocumentLock = newdoc.LockDocument()
                docs.MdiActiveDocument = newdoc
                Dim newdb As Database = HostApplicationServices.WorkingDatabase
                Using tr As Transaction = newdb.TransactionManager.StartTransaction()
                    Dim lmr As LayoutManager = LayoutManager.Current
                    Try
                        Dim layout As Layout = Nothing
                        Try
                            layout = DirectCast(tr.GetObject(lmr.GetLayoutId("Blocks"), OpenMode.ForRead), Layout) ' <-- your layout name here
                        Catch exl As Autodesk.AutoCAD.Runtime.Exception
                            ed.WriteMessage("Error on swith to Layout: {0}" & vbLf & "{1}" & vbLf, "Blocks", exl.Message)
                        End Try
                        LayoutManager.Current.CurrentLayout = layout.LayoutName
                        tr.Commit()
                        ed.WriteMessage((vbLf + ex.Message & vbLf) + ex.StackTrace & vbLf)
                    Finally
                        ed.WriteMessage(vbLf + "I hope you're satisfied with the result." + vbLf)
                    End Try
                End Using
            End Using
        End Sub
        Public Sub OpenDocCallback(Data As Object)
            ' Open the document here, whose name was passed in
            ' the Data parameter
            If is_template Then
                docs.Add(Data.ToString())
            Else
                docs.Open(Data.ToString(), False, "")
                ' documents is already open and activated, pass your utility here:
                'Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument.Editor.RunCommand("my cool command, etc");//2014
            End If
        End Sub
End Class
Change a drawing name and layout name in the code,
Cheers
Valued Contributor
andred
Message 10 of 10 (456 Views)
08-26-2013 06:05 AM in reply to: andred
Thank you Hallex for your code.
It is working well but it does work differently depending of NEXTFIBERWORLD setting. When set to 0, the MIDACTIVEDOCUMENT is not set to the new open document. In your code, you use "newdb" pointing to the database of the just open drawing to get information about layouts.
            MessageBox.Show(docs.MdiActiveDocument.Name)
            MessageBox.Show(newdb.Filename)
NEXTFIBERWORLD=1: The message boxes displays the same drawing name
NEXTFIBERWORLD=0: The first message box displays "Drawing1" (or the name of the current drawing).
So each time I have to get information about this drawing I have to set a database variable, not use the current one. This is a litte bit annoying because I have to pay attention at this each time I want to access current document information. But it is a good workaround.
Thanks a lot!
André
