.NET
mpalan2009
Message 1 of 4 (228 Views)
Set CurrentLayout
228 Views, 3 Replies
01-07-2013 05:16 AM
Can someone please tell me why I get an 'esetfailed' error?  I must be missing something simple.  Just before this sub I call another sub that changes the active document. ?? This is in AutioCAD 2011 w/ 64bit environment.
    Public Shared Sub ActiveLayout(ByVal name As String)
        Dim acDoc As Document = AcApp.DocumentManager.MdiActiveDocument
        Dim Db As Database = HostApplicationServices.WorkingDatabase
        Dim tdoclock As DocumentLock = acDoc.LockDocument
        Dim layMgr As LayoutManager = LayoutManager.Current
        Using acTrans As Transaction = Db.TransactionManager.StartTransaction()
            Try
                Autodesk.AutoCAD.ApplicationServices.Application.ShowAlertDialog(acDoc.Name)
                If Not Regex.Match(layMgr.CurrentLayout, name).Success() Then
                    layMgr.CurrentLayout = name
                End If
                acTrans.Commit()
            Catch ex As Autodesk.AutoCAD.Runtime.Exception
                Autodesk.AutoCAD.ApplicationServices.Application.ShowAlertDialog(ex.Message & vbCr & ex.HelpLink & vbCr & ex.StackTrace)
            Finally
                acTrans.Dispose()
                tdoclock.Dispose()
                tdoclock = Nothing
            End Try
        End Using
    End Sub
Any help is greatly appreciated.
Matthew
_gile
Message 2 of 4 (207 Views)
Re : Set CurrentLayout
01-07-2013 08:34 AM in reply to: mpalan2009
eSetFailed is probably due to the fact the 'name' Layout does not exist in the drawing and no need to complicate so much.
This works for me:
            Try
                LayoutManager.Current.CurrentLayout = name
            Catch
                MsgBox(String.Format("Layout '{0}' not found", name))
            End Try
        End Sub
Gilles Chanteau
mpalan2009
Message 3 of 4 (199 Views)
01-07-2013 10:30 AM in reply to: _gile
I would like to change the question.  Why does that code not work for Drawing1.dwg and Layout1?  It does work with other drawings I have.  I don't have a reason to operate on that drawing, So I will exclude it from the forms listbox.
Matthew
Hallex
Message 4 of 4 (181 Views)
01-07-2013 01:33 PM in reply to: mpalan2009
Delete "acTrans.Dispose" from Finally code block
and try again
