I've been using my own implementation of the "Create and enable a floating Viewport" from the AutoCAD 2011 Developer's Guide here, and everything works fine on a 32 bit system, but on 2 different Windows 7 64-bit systems, the following line results in a error:
//The reason I point this to the specific .exe file is because I have several versions of AutoCAD installed, and I wasn't sure how it knew which one to import the command from.[DllImport("c:\\Program Files\\Autodesk\\AutoCAD 2011\\acad.exe", CallingConvention = CallingConvention.Cdecl, EntryPoint = "?acedSetCurrentVPort@@YA?AW4ErrorStatus@Acad@@PBVAcDbViewport@@@Z")] extern static private int acedSetCurrentVPort(IntPtr AcDbVport);
The error I receive is:
See the end of this message for details on invoking just-in-time (JIT) debugging instead of this dialog box. ************** Exception Text ************** System.EntryPointNotFoundException: Unable to find an entry point named '?' in DLL 'c:\Program Files\Autodesk\AutoCAD 2011\acad.exe'. at Autodesk.AutoCAD.CreateLayouts.MyCommands.acedSetCurrentVPort(IntPtr AcDbVport) at Autodesk.AutoCAD.CreateLayouts.LayoutCommands.AddNewVports(String LayoutName, ObjectId BlockId, List`1 newvport) in F:\My Documents\Visual Studio 2010\Projects\CreateLayouts\CreateLayouts\myCommands.cs:line 2723 at Autodesk.AutoCAD.CreateLayouts.LayoutCommands.CreateNewLayouts(List`1 jobdetail, ObjectId BlockId, List`1 newvport) in F:\My Documents\Visual Studio 2010\Projects\CreateLayouts\CreateLayouts\myCommands.cs:line 2840 at Autodesk.AutoCAD.CreateLayouts.MyCommands.BeginCreateLayouts(Dictionary`2 kpdict) in F:\My Documents\Visual Studio 2010\Projects\CreateLayouts\CreateLayouts\myCommands.cs:line 549 at Autodesk.AutoCAD.CreateLayouts.MyCommands.CreateLayouts() in F:\My Documents\Visual Studio 2010\Projects\CreateLayouts\CreateLayouts\myCommands.cs:line 262 at Autodesk.AutoCAD.Runtime.CommandClass.InvokeWorker(MethodInfo mi, Object commandObject, Boolean bLispFunction) at Autodesk.AutoCAD.Runtime.CommandClass.InvokeWorkerWithExceptionFilter(MethodInfo mi, Object commandObject, Boolean bLispFunction) at Autodesk.AutoCAD.Runtime.PerDocumentCommandClass.Invoke(MethodInfo mi, Boolean bLispFunction) at Autodesk.AutoCAD.Runtime.CommandClass.CommandThunk.Invoke() ************** Loaded Assemblies ************** mscorlib Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.4952 (win7RTMGDR.050727-4900) CodeBase: file:///C:/Windows/Microsoft.NET/Framework64/v2.0.50727/mscorlib.dll ---------------------------------------- acdbmgd Assembly Version: 18.1.0.0 Win32 Version: 18.1.115.0.0 CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202011/AcdbMgd.DLL ---------------------------------------- msvcm90 Assembly Version: 9.0.30729.4926 Win32 Version: 9.00.30729.4926 CodeBase: file:///C:/Windows/WinSxS/amd64_microsoft.vc90.crt_1fc8b3b9a1e18e3b_9.0.30729.4926_none_08e1a05ba83fe554/msvcm90.dll ---------------------------------------- PresentationFramework Assembly Version: 3.0.0.0 Win32 Version: 3.0.6920.5001 built by: Win7RTMGDR CodeBase: file:///C:/Windows/assembly/GAC_MSIL/PresentationFramework/3.0.0.0__31bf3856ad364e35/PresentationFramework.dll ---------------------------------------- WindowsBase Assembly Version: 3.0.0.0 Win32 Version: 3.0.6920.5001 built by: Win7RTMGDR CodeBase: file:///C:/Windows/assembly/GAC_MSIL/WindowsBase/3.0.0.0__31bf3856ad364e35/WindowsBase.dll ---------------------------------------- System Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.4927 (NetFXspW7.050727-4900) CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll ---------------------------------------- PresentationCore Assembly Version: 3.0.0.0 Win32 Version: 3.0.6920.5001 built by: Win7RTMGDR CodeBase: file:///C:/Windows/assembly/GAC_64/PresentationCore/3.0.0.0__31bf3856ad364e35/PresentationCore.dll ---------------------------------------- System.Drawing Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.4927 (NetFXspW7.050727-4900) CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Drawing/2.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll ---------------------------------------- System.Xml Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.4927 (NetFXspW7.050727-4900) CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Xml/2.0.0.0__b77a5c561934e089/System.Xml.dll ---------------------------------------- System.Configuration Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.4927 (NetFXspW7.050727-4900) CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Configuration/2.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll ---------------------------------------- AdApplicationFrame Assembly Version: 0.0.0.0 Win32 Version: 3.0.269.0 CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202011/AdApplicationFrame.DLL ---------------------------------------- AdWindows Assembly Version: 3.0.263.0 Win32 Version: 3.0.263.0 CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202011/AdWindows.DLL ---------------------------------------- PresentationFramework.Aero Assembly Version: 3.0.0.0 Win32 Version: 3.0.6920.4902 built by: NetFXw7 CodeBase: file:///C:/Windows/assembly/GAC_MSIL/PresentationFramework.Aero/3.0.0.0__31bf3856ad364e35/PresentationFramework.Aero.dll ---------------------------------------- acmgd Assembly Version: 18.1.0.0 Win32 Version: 18.1.115.0.0 CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202011/acmgd.DLL ---------------------------------------- AcWindows Assembly Version: 18.1.0.0 Win32 Version: 18.1.115.0.0 CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202011/AcWindows.DLL ---------------------------------------- System.Core Assembly Version: 3.5.0.0 Win32 Version: 3.5.30729.4926 built by: NetFXw7 CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Core/3.5.0.0__b77a5c561934e089/System.Core.dll ---------------------------------------- AcWindows.resources Assembly Version: 18.1.0.0 Win32 Version: 18.1.49.0.0 CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202011/en-US/AcWindows.resources.DLL ---------------------------------------- AcCui Assembly Version: 18.1.0.0 Win32 Version: 18.1.115.0.0 CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202011/AcCui.DLL ---------------------------------------- ContextualTabSelectorRules Assembly Version: 0.0.0.0 Win32 Version: 18.1.115.0.0 CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202011/AcWindows.dll ---------------------------------------- System.Windows.Forms Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.4927 (NetFXspW7.050727-4900) CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Windows.Forms/2.0.0.0__b77a5c561934e089/System.Windows.Forms.dll ---------------------------------------- ManagedMC3 Assembly Version: 4.11.0.0 Win32 Version: 4.12.0.0 CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202011/ManagedMC3.DLL ---------------------------------------- UIAutomationProvider Assembly Version: 3.0.0.0 Win32 Version: 3.0.6920.4902 built by: NetFXw7 CodeBase: file:///C:/Windows/assembly/GAC_MSIL/UIAutomationProvider/3.0.0.0__31bf3856ad364e35/UIAutomationProvider.dll ---------------------------------------- CreateLayouts Assembly Version: 1.0.3989.31668 Win32 Version: 1.0.0.0 CodeBase: file:///F:/My%20Documents/Visual%20Studio%202010/Projects/CreateLayouts/CreateLayouts/bin/debug/CreateLayouts.dll ---------------------------------------- ************** JIT Debugging ************** To enable just-in-time (JIT) debugging, the .config file for this application or computer (machine.config) must have the jitDebugging value set in the system.windows.forms section. The application must also be compiled with debugging enabled. For example: <configuration> <system.windows.forms jitDebugging="true" /> </configuration> When JIT debugging is enabled, any unhandled exception will be sent to the JIT debugger registered on the computer rather than be handled by this dialog box.
I guess there must be something I'm missing - the application I'm building works just fine on 32 bit AutoCAD Civil 3D 2009, yet on 64 bit AutoCAD 2011 it fails every time.
Solved by AlexFielder. Go to Solution.
I think I might have just fixed this issue myself. After googling the exact error message:
"Unable to find an entry point named '?' in DLL"
I ended up here:
This then pointed me to http://www.dependencywalker.com/
After downloading and running this tool on acad.exe I found the function I was looking for.
In the attached image you'll see what the correct external call should be.
tl;dr: use this:
?acedSetCurrentVPort@@YA?AW4ErrorStatus@Acad@@PEBVAcDbViewport@@@Z
instead of this:
I'm not sure if this affects the 32 bit version of AutoCAD 2011, as I don't have it installed anywhere.
Your solution is 7 years old now, so I was wondering if this is still the only method of setting the current paperspace viewport? If not is there a way to find the location of accore.dll for the version of autocad being used?
buttcrackbob a écrit :
In my case, all I've got is viewport objectid. I don't think I can obtain the viewport number from the viewport object. It my exist in the layout object, but I think those numbers are assigned when the layout is open.
It seems to me the layout have to be opened to set current one of its viewport...
