Hi all,
Is it possible to access a nested block within a specific block reference to change the annotation scale?
I'm not sure it is and from my understanding. The scales attached to the nested block should be applicable to all block references.
Strange thing is that I managed to get two different nested block scales occuring on the one block record playing with AUTOANNOSCALE. Maybe it's just a bug but if it's possible it would be handy.
Edit
You might need to turn AUTOANNOSCALE off to see that one block has a fixed scale. One has scales attached of 1:50 &
1:100. The other fixed at 1:100. Both only have 1:100 when you look at it in the editor.
