.NET
Set ActiveLayer Problem...
6 REPLIES 6
Explosive_Ice
3190 Views, 6 Replies
Hi, everybody! ADSK have a bug in choosing activelayer, when the AutoCAD Object was created by CreateObject("AutoCAD.Application") in .NET.
How could I choose an activelayer anyway?
Here the code:
Dim CurrentLayer As Object
Dim LayerName As String = "Test Layer"
AutoCADObject = CreateObject("AutoCAD.Application.17")
AutoCADObject.Visible = True
AutoCADObject.ActiveDocument.Layers.Add(LayerName)
CurrentLayer = AutoCADObject.ActiveDocument.Layers.Item("Test Layer")
AutoCADObject.ActiveDocument.ActiveLayer = CurrentLayer
Catch ex As Exception
Debug.WriteLine(ex.Message)
End Try
I have exception:
"Member not found."
Thanx a lot.....
6 REPLIES 6
Well i don't understand why people want to use .NET to create COM applications, after all thats what VBA is all about...... But if you insist.
Try
dim CurrentLayer as AcadLayer
let me know if that doesn't work. 🙂
You can't use dim CurrentLayer as AcadLayer because, there is no reference to AutoCAD, we have CreateObject and can not to define sub-objects of AutoCAD. Whatever, Thanx for your reply...
in reply to: Explosive_Ice
http://www.autocad.ru/cgi-bin/f1/board.cgi?t=30612rJ#20061018210721
Well this code works for me.....
Imports Autodesk.AutoCAD.Interop
Imports Autodesk.AutoCAD.Interop.Common
Public Class Form1
Private Sub Button1_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles Button1.Click
Dim CurrentLayer As AcadLayer
Dim AutoCADObject As AcadApplication = CreateObject("AutoCAD.Application.16")
CurrentLayer = AutoCADObject.ActiveDocument.Layers.Item(LayerName)
Try
End Try
End Sub
End Class
Why can't you add a reference?
are you working with multiple versions of AutoCAD?
personally i've had nothing but bad experiences with late binding..... maybe if you could provide more info we could help you.
Yes, I need it for multiple versions of AutoCAD, without reference to specified version. In VB6 it works correctly, in .NET thet's problem with casting in lines like AutoCADObject.ActiveDocument.ActiveLayer = CurrentLayer
or also
Dim outerLoop As Object
outerLoop = AutoCADObject.ActiveDocument.ModelSpace.AddPolyline(HatchPoint)
hatchObj.AppendOuterLoop(outerLoop)
This code also drops to error in .NET and works fine in VB6
I'm having this exact same problem... did you ever find an answer to it??
I'm using late binding as well since I have multiple versions of AutoCAD that I'm working with from a .NET application. My code is:
V_AutoCadLayer = V_AutoCad.ActiveDocument.Layers.Add("E9BorderLayer")
V_AutoCadLayer.Color = 3
V_AutoCad.ActiveDocument.ActiveLayer = V_AutoCadLayer
I get an error on the last line where I set ActiveLayer, it returns "Member not found."
”Boost
