.NET
Server Execution Failed when trying New AcadApplication in service
4 REPLIES 4
jamesmcg
784 Views, 4 Replies
I'm working on a service that links into AutoCAD. The service is supposed to automatically do conversions, however, when it gets to this line:
_autoCad = New AcadApplication
it throws this exception:
Server execution failed
I am using VB.Net in visual studio 2003 with .NET 1.1.4322 and AutoCAD 2010. I have "Imports AutoCAD" and the AutoCAD 2010 Type Library referenced.
Thanks for any tips. I searched the forums and all i found was this thread-http://discussion.autodesk.com/forums/message.jspa?messageID=5112009, but i disabled the communication center, and i still encountered the error
4 REPLIES 4
in reply to: jamesmcg
What kind of service you are creating? Windows service? web/wcf service?...
If it is Windows service, the service is not allowed to run desktop
application. Technically, you may be able to run Acad on a web server with
web application/services with certain configuration, but pratically not an
viable solution. That is why the "=New AcadApplication" statement fails. Not
to mention possible violation of Acad lisence by running it by "service".
You need to rethink/redesign your solution, I am afraid.
"jamesmcg" wrote in message news:6319467@discussion.autodesk.com...
jamesmcg
Yes, it's a windows service. It's worked in the past, with a previous version (2006, I believe)
btmsoftware
I've read in those forums that removing/disabling the Acad communication center allows running Acad as a services. It is the gulty one regardin Acad hanging
Have you tried that ?
hgasty1001
While i don't know if you can run AutoCAD as a service, i do know that you need at least .NET 2.0 Framework (up to 4.0, but not supported nor recommended and with some limitations)  and VS 2008 (i'm not sure if VS 2005 does the cut) to compile and debug .NET code in AutoCAD 2010.
Gaston Nunez
”Boost
