.NET
Sent to front an open document
4 REPLIES 4
271 Views, 4 Replies
Hi
I am opening a drawing using the application documents object open method and it opens sucessfully but, it is sent back of the current document windows. I then use the document object active method to bring it to front, but I discovered that by doing so, it interrupts the program execution unless I activate the window that I want to keep on the back. Is there a way to open a drawing, keep it to the front and continue the program execution?
I will appreciate any help
4 REPLIES 4
jbulzomi
Im having the same problem...
Can someone please help.
this is how i am calling the file-open
Dim file As Document = Application.DocumentManager.Open(filename, False)
I then attempt to zoom in by calling
Application.DocumentManager.MdiActiveDocument.SendStringToExecute("_Zoom _E ", False, True, False
The file will load but behind the default drawing1.dwg document. I need it to load in the foreground and remain there.
Any help much appreciated...
Did you ever find out how to do this, its been bugging me for days now.
Have you tried setting MdiActiveDocument to the newly opened Document?
For example:
Application.DocumentManager.MdiActiveDocument = file
Your code must be running in the application context
in order to switch active documents.
http://www.caddzone.com
AcadXTabs: MDI Document Tabs for AutoCAD 2008
Supporting AutoCAD 2000 through 2008
http://www.acadxtabs.com
wrote in message news:5683442@discussion.autodesk.com...
”Boost
