.NET
Valued Contributor
rtejada
Message 1 of 5 (74 Views)
Sent to front an open document
74 Views, 4 Replies
12-02-2005 05:15 AM
Hi
I am opening a drawing using the application documents object open method and it opens sucessfully but, it is sent back of the current document windows. I then use the document object active method to bring it to front, but I discovered that by doing so, it interrupts the program execution unless I activate the window that I want to keep on the back. Is there a way to open a drawing, keep it to the front and continue the program execution?
I will appreciate any help
Active Member
jbulzomi
Message 2 of 5 (73 Views)
Re: Sent to front an open document
05-10-2006 07:04 PM in reply to: rtejada
Im having the same problem...
Can someone please help.
this is how i am calling the file-open
Dim file As Document = Application.DocumentManager.Open(filename, False)
I then attempt to zoom in by calling
Application.DocumentManager.MdiActiveDocument.SendStringToExecute("_Zoom _E ", False, True, False
The file will load but behind the default drawing1.dwg document. I need it to load in the foreground and remain there.
Any help much appreciated...
New Member
phoenixbs
Message 3 of 5 (73 Views)
08-08-2007 07:57 AM in reply to: rtejada
Did you ever find out how to do this, its been bugging me for days now.
Distinguished Contributor
mohnston
Message 4 of 5 (74 Views)
08-10-2007 08:33 AM in reply to: rtejada
Have you tried setting MdiActiveDocument to the newly opened Document?
For example:
Application.DocumentManager.MdiActiveDocument = file
CAD Programming Solutions
*Tony Tanzillo
Message 5 of 5 (74 Views)
08-10-2007 12:50 PM in reply to: rtejada
Your code must be running in the application context
in order to switch active documents.
http://www.caddzone.com
AcadXTabs: MDI Document Tabs for AutoCAD 2008
Supporting AutoCAD 2000 through 2008
http://www.acadxtabs.com
wrote in message news:5683442@discussion.autodesk.com...
