.NET
SendStringToExecute
7 REPLIES 7
Message 1 of 8
574 Views, 7 Replies
SendStringToExecute
SendStringToExecute
I'm having a problem with this, if the user has typed
something on the command line, but has not pressed
enter.
Is there any API (C++, undocumented or not) that can
tell me if keystrokes have been typed at the "Command: "
prompt, but enter/space hasn't been pressed?
http://www.caddzone.com
AcadXTabs: MDI Document Tabs for AutoCAD 2004/2005/2006
http://www.acadxtabs.com
7 REPLIES 7
Message 2 of 8
Tony:
Maybe 'acedIsInputPending' exported by acad.exe? I've never tried it, but
it's a good bet. 🙂
Owen Wengerd
President, ManuSoft ==> http://www.manusoft.com
VP Americas, CADLock, Inc. ==> http://www.cadlock.com
Message 3 of 8
Hi Owen. Thanks, tried that, no luck.
I know AutoCAD checks this, because it doesn't
respond to mouse clicks in the drawing window if
there's something typed.
"Owen Wengerd" wrote in message news:4893409@discussion.autodesk.com...
Tony:
it's a good bet. 🙂
Owen Wengerd
Message 4 of 8
Have you tried Application.IsQuiescent ?
Albert
"Tony Tanzillo" wrote in message
news:4894610@discussion.autodesk.com...
Tony:
it's a good bet. 🙂
Owen Wengerd
Message 5 of 8
Hi Albert - That did it, thanks.
"Albert Szilvasy" wrote in message news:4895269@discussion.autodesk.com...
Albert
Tony:
it's a good bet. 🙂
Owen Wengerd
Message 6 of 8
If IsQuiescent returns false when keystrokes are on the
command line, why does Editor.LeavingQuiescentState
not fire when the first keystroke is typed?
And, if I erase all of the keystrokes with Backspace,
then shouldn't EnteringQuiescentState fire?
Albert
Tony:
it's a good bet. 🙂
Owen Wengerd
Message 7 of 8
Sound like a bug to me but I suspect it has been this way for long enough
that fixing it would cause harm than good.
Albert
news:4895896@discussion.autodesk.com...
Albert
Tony:
it's a good bet. 🙂
Owen Wengerd
Message 8 of 8
Thanks. You might want to make note that when dynamic
input is enabled and keystroke input goes to the edit box
at the cursor, IsQuiescent returns true even when keystrokes
have been entered.
"Albert Szilvasy" wrote in message news:4895873@discussion.autodesk.com...
Albert
Albert
Tony:
it's a good bet. 🙂
Owen Wengerd
”Boost
